Old 10-14-2018, 06:01 PM
mwood65's Avatar
mwood65 mwood65 is offline
Winshield wiper switch
I am having trouble finding a knob that fits my wiper switch and was wondering if you guys had any answers.
The switch has a hexagon shaped place where the knob sets and then a longer post sticking out the middle (washer switch?)
My switch looks like this one...
The knobs I ordered do not work and only have a hole with a spring steel type locking thingie on it to lock it onto the shaft (make any sense?)
Does anyone know what knob fits this type switch and maybe where I could get one?
Oh, it's a 1974 Cherokee.....
Old 10-15-2018, 08:21 AM
I think you need the older chrome knob that was held on with a screw. I don't think you can buy a new one you'll need to find a used one.
Old 10-15-2018, 06:06 PM
mwood65's Avatar
Would it be hard to upgrade to a newer switch maybe?
If not does anyone have the old knob they want to part with?
Old 10-15-2018, 07:38 PM
jsinajeep's Avatar
I may have one. Will not be able to check until I get home in a couple of days.
Old 10-16-2018, 08:33 AM
airman's Avatar
airman airman is offline
I bought a new switch from LMC truck.
Just the switch thy might have the knob also.
It was listed for late 60's pickup
The wiper system is a GM
Andrew
1969 J3000 Dauntless 350, T15, D20
1970 CJ6 Dauntless 350 , T350, D20
1951 CJ3A in the wings
Old 10-16-2018, 08:51 AM
GM never used the chrome knob. the switch might work but it won't look right.
Old 10-16-2018, 12:00 PM
mwood65's Avatar
Ok buddy, let me know and I will get with you on it.
Old 10-16-2018, 12:45 PM
asphaltrockdweller's Avatar
The knob that your jeep uses has a center button that pushes in the washer switch portion of the wiper switch assembly to activate the pump.
In late 1975 they changed the switch and knob to a "one-piece". The switch no longer had the button in the middle to activate the washer pump.
Old 10-20-2018, 06:24 AM
fsj454 fsj454 is offline
Long time member
washer
I have the switch knob . but do not have the pusher dohikky that goes on the brass switch . Do you have that dohikky thing . My knob is in perfect shape has allen key and works no cracks been in my draw 25 years .I SAVED THIS FOR YOU I GUESS
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 10-21-2018, 05:37 PM
mwood65's Avatar
I don't have the push dohicky......just the switch is better than I have now.
Wiper Switch Wiring Diagram 63 J 300 General FSJ Tech 1 10-01-2016 10:57 AM
Rear Window Switch Thread?? CJ5 General FSJ Tech 21 02-20-2013 08:08 PM
Picture of stock 73 wiper switch? autoarcheologist General FSJ Tech 22 12-10-2011 12:26 AM
overhauling steering column - need wiper switch assy hey BJ's did i miss something? Tripwire General FSJ Tech 5 11-14-2009 03:18 PM
Wiper switch question Charlie_B General FSJ Tech 7 01-05-2006 03:09 AM
