Old 11-15-2014, 12:57 PM
90supra's Avatar
90supra 90supra is offline
Blown Head Gasket
...I thought I left that phrase when I got rid of my Supra..
Anyway, looks like I have a blown head gasket on the GW. Have the milkshake on the oil cap, coolant usage for quite awhile (that I thought was a leak), and now a coolant leak the appears to be coming from the passenger head. I haven't had any overheating issues (max it has seen in my ownership is about 225-230) and that was a few months ago. Any other definitive tests to look into before tearing into it?
Also, is there any head gaskets to stay away from? I was planning on just getting the Fel-pro kit. And what is the opinion on re-using head bolts?
1967 J3600: 258, T18, D20, MC 2100
1987 Grand Wagoneer: 360/727/229, howell TBI, thorley headers, rusty's 4"
Old 11-15-2014, 06:22 PM
Just "my opinion". If I'm building a fresh motor I go with new bolts. For maint repair work if the bolts aren't stretched or the threads deformed I reuse them. Either way you go you'll still have to re-torque them after a few heating/cooling/running cycles. I usually go with 200 miles and re-torque and check again at about 500 miles. Just my SOP and not chiseled in stone gospel.
Old 11-15-2014, 09:13 PM
ZiRiu's Avatar
ZiRiu ZiRiu is offline
Can you get head bolts at a hardware store? If so it wouldn't be more than 30 cents apiece to replace them.
1981 Wagoneer
360, TF727, NP-219 T-Case, D44 front, AMC 20 rear.
Old 11-15-2014, 09:26 PM
Head bolts at a hdw store for 30 cents at a pop? NO.
Old 11-15-2014, 09:31 PM
ZiRiu's Avatar
Just curious. I've matched small screws for stuff at hardware stores but I guess head bolts are a bigger deal if they all crack and separate on the highway.
1981 Wagoneer
Old 11-15-2014, 09:52 PM
Ive read that the felpro 1008 is a good head gasket.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 11-15-2014, 10:00 PM
thechier86's Avatar
thechier86 thechier86 is offline
I just bought a waggy with an identical symptom set. I'm thinking mine might be a leaky intake gasket since it never overheats. Check the plugs to see if there's any evidence of coolant getting in any of the cylinders? I don't really know. I'm gonna try the intake gasket this weekend, and start saving for a diesel swap....
buckle up, i wanna try somethin...
Old 11-15-2014, 10:42 PM
90supra's Avatar
The lack of overheating did make me wonder but would a leaky intake gasket lead to the 'milkshake' oil? That was one of my major thoughts on it being BHG or worse.
Old 11-16-2014, 07:15 AM
Possibly could, yes. Leaking antifreeze right into the valley area.
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
Old 11-16-2014, 07:29 AM
OutrageGIS's Avatar
OutrageGIS OutrageGIS is offline
Is the oil milky or just the breather cap on the oil fill tube? The breather cap catches condensation from the atmosphere and will usually look milky in cool temps. Change the oil before you tear into a head job. Coolant leak could be from intake gasket or thermostat housing or water pump, the fan tends to spray coolant around the engine compartment. Just some things to check before pulling the top of your motor apart!
79 Cherokee, 360, QT, Stocky
At Large Board Member, Central South-East Jurisdiction, Elijah Craig Chapter, Bluegrass Division, FSJ Prissy Restoration Association
Old 11-16-2014, 04:36 PM
90supra's Avatar
Quick thought- Do the longer water pump bolts need thread sealer?
Old 11-17-2014, 01:49 PM
I always use it to be sure on those.
Old 11-24-2014, 08:18 AM
90supra's Avatar
Update-
I took the longer bolts for the water pump, and accessories off, added thread sealer, and torqued to spec and this seems to have remedied my coolant leak which I thought had confirmed my fears. Took it for a longer drive and no "milkshake" on the oil cap and no notable coolant usage. Thanks for the advice here, probably saved myself quite the headache tearing into it
Old 11-24-2014, 10:19 PM
THIS
-Jonny B.
D20 - Twin Stick'd
F D44 - 4.10, Eaton E-Locker
R D44 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Leaking head gasket! Need engine advice, copper head gaskets, etc. PlasticBoob General FSJ Tech 2 09-13-2005 01:24 PM
Is this a blown head gasket? (update at bottom) JeepsAndGuns General FSJ Tech 32 08-09-2004 05:10 AM
401 head gasket trouble--HELP! chrisnsarah General FSJ Tech 7 08-15-2003 03:58 PM
It wasn't a blown head gasket gbarrett General FSJ Tech 4 07-01-2001 05:51 PM
Blown Head Gasket GRAT General FSJ Tech 1 12-10-2000 05:19 AM
