Old 04-09-2010, 08:58 PM
toolthrower's Avatar
toolthrower toolthrower is offline
do i reuse my vally pan with rpm air gap
I am replacing my stock 2 barrel intake with a edelbrock rpm air gap intake do i reuse the valley pan or replace it. thecoolant passages in the pan are rusted around the inside edges
Old 04-09-2010, 09:07 PM
CutterN55's Avatar
Nope don't think so. Pretty sure that's a crush type.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 04-09-2010, 09:15 PM
The Colonel's Avatar
X2, needs to be replaced.
Old 04-09-2010, 09:17 PM
Gas Pumper's Avatar
Gas Pumper Gas Pumper is offline
X3. I made that mistake when I installed my Performer intake.
FSJ-less...
...at the moment...
Old 04-09-2010, 09:27 PM
CutterN55's Avatar
What happened? Vac, exhaust, coolant leaks?
I always changed it as I was shown as a kid and was told it's a crush type & you can only use it once so don't jack it up.
ROMANS 12:1-2
'89 GW deceased
Old 04-09-2010, 10:02 PM
Gas Pumper's Avatar
Slight coolant and oil burn. They are crush type. I had to tear off my manifold and do it all over again. Not fun.
FSJ-less...
...at the moment...
Old 04-09-2010, 10:25 PM
FSJ Guy FSJ Guy is offline
Get a new one. They're cheap and they're single use only.
Ethan Brady
www.bigscaryjeep.com
Old 04-10-2010, 08:42 AM
Songman's Avatar
Songman Songman is offline
Yeah, since it is not just a valley pan but also the manifold gaskets, change it. I have my new one here in the box from BJs and as soon as my GW gets back home the four barrel intake and carb is going on it.
Old 04-10-2010, 03:17 PM
the instructions that came with the edelbrock intake said to use a gasket and the valley pan i set the intake on and i dont think that i can get the bolts in not sure what to do about that any one else had that problem
Old 04-10-2010, 03:26 PM
Is this a new intake? What part number is it? If it's for an early AMC the center bolt holes may need to be slotted.
Old 04-10-2010, 03:43 PM
yes it is new and its not just the center bolts its all of them because of both gaskets and valley pan i was thinking of just using the valley pan
Old 04-10-2010, 03:54 PM
Gas Pumper's Avatar
I also used just the valley pan and a little RTV around each port. Don't use the rubber end gaskets, either. Just use RTV.
FSJ-less...
...at the moment...
Old 04-10-2010, 04:08 PM
was that with a elelbrock intake
Old 04-11-2010, 09:22 PM
HARDCORE pacer's Avatar
HARDCORE pacer HARDCORE pacer is offline
just get a mr gasket part # 800G and throw away the valley pan and gasket that came with the intake.
78 pacer on 75 chero frame thats shortened 10\" and shackle reversal, D60 front with spool,14ff with detroit locker 4.56s in both,500 hp/500 ftlb torque 401,built 727,208 to divorced 205 doubler,on 46x21 ag tires
78 cj 360, 3spd, scout 44s with detroits SOAed with 36"tsl and beadlocks
Old 04-12-2010, 07:35 AM
710 Burner's Avatar
You have to "seat" a new valley pan a bit. Start a couple of bolts on one side, then tap the other side down with a rubber mallet until you can start some bolts on that side.
Mark B. Jones
Old 04-12-2010, 10:23 AM
CutterN55's Avatar
When I did mine, I didn't use any gasket other than the valley pan IIRC. I did use some red RTV around the ports and I put a slight bend in the valley pan where I could insert the pins and not have it spring out and get RTV everywhere. Also, don't use the end seals that come with a new valley pan gasket as they will slip bad. Edelbrock recommends using RTV on the ends. I put a nice 1/4" bead of Ultra Black and it works good. Make sure you get the bead in the corners real good. I laid it on much like a weld should look ensuring it was uniform across the surface and would have enough on the top of the bead to get good contact when I set the manifold down. I had no issues with bolts as I was super careful laying the manifold in straight down. I let the RTV set awhile before torquing the bolts all the way down to get a good squish.
ROMANS 12:1-2
'89 GW deceased
Testing the AIR diverter valve srobertsfsj General FSJ Tech 3 03-27-2010 04:41 PM
Air filter caught on fire jeepjseries General FSJ Tech 9 03-22-2010 07:22 AM
dual snorkle, too much air? RottenDog General FSJ Tech 2 03-03-2010 02:55 PM
Cold air intake for a 360 ralf General FSJ Discussion 11 03-01-2010 05:40 PM
