Old 01-26-2010, 11:29 AM
joe71's Avatar
joe71 joe71 is offline
electronic ignition conversion question
Anyone out there had any experience with the Pertroxix kits or the Mallory Unilite? I noticed that Pertronix makes 3 different ones (1,2 and3). I had a Mallory dist. im my pro street Chevy and it worked pretty good. I'm just not too familiar with the Pertronix stuff. Thanks for your input.
Old 01-26-2010, 11:32 AM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
From what I gather the Pertronix unit just replaces the points, since you have a Delco Dizzy, and there were about a zillon more Chev's built than Jeeps, you might want to find a Chevy fourm, sure there would be many more with that exact setup than here.
Mike D.
Old 01-26-2010, 11:46 AM
joe71's Avatar
Ok thanks. It seems that most of the guys here use the Pertronix kit. I'll give her a try
Old 01-26-2010, 11:50 AM
710 Burner's Avatar
IIRC the UniLite is an IR emitter/reciever that you put in place of the points.
Mark B. Jones
Old 01-26-2010, 01:28 PM
The Pertronix units are a reliable user friendly option for folks that can't or won't deal with points ignitions. The Mallory unit is more for the performance crowd. The Pertronix units are reliable and well proven, they even make'm for old MB's. For my tastes I'd go HEI but between your two options I'd go Pertronix for a daily driver.
Old 01-26-2010, 01:59 PM
Rod2's Avatar
Rod2 Rod2 is offline
I've had a Pertonix module in my original dist'r for about 3yrs now and I would highly recommend the upgrade.
While I had the dist'r out, I found the roll pin holding the gear on to be worn and loose--which may have contributed to an erratic idle. Either way, it starts fine and runs better than ever.
Rod Skaggs
'73 J4000 'WOOD GO' 360, 2100 MC, T-18, D-20, 60-2 rear, D-44 closed knuckle front with Warn Lock-O-Matics, Eaton E-lockers both, Pertronix module, AC, PS, '77 Firebird tilt column, Hydro-boost, AirLift bags front and rear, 33x15 Goodyear MTR's, Pacer 15x8 aluminum Bullet Holes, Summit line lock, 3rd brake light, MileMarker 12,000 cradle mounted winch
Old 01-26-2010, 02:07 PM
joe71's Avatar
Ok, thanks for the info guys. Like I said, I've used Mallory stuff before with good results but (as I'm new to FSJ's) I really didn't know much about the Pertronix kit. I'll give it a try.
Old 01-26-2010, 03:25 PM
amcboy's Avatar
amcboy amcboy is offline
Ive used the factory (ok, rebuilt) Motorcraft dizzy hooked to a MSD 6AL box.
Got this setup in the AMX now.
The M-craft triggers are generally good.
Questions?
Answers?
amcboy
And then there was none...
'70 AMX (AMC power!)
'71 TR-6 (I know, NOT a FSJ. But rusts like one...)
Max horsepower is at a single point and is called bar room horsepower
Old 01-26-2010, 03:31 PM
letank's Avatar
letank letank is offline
Used one for 80kmiles / 10 years, worked really well... then slowly died on my way back from Moab.... the engine died in the driveway!
Michel
