Old 07-06-2009, 10:55 PM
pablo_max pablo_max is offline
401 Mystery
For a while it was a mystery for me why I had a 401 installed in my 72 wagoneer since they were not an option until 74.
However, why doing my wiring I noticed my VIN plaque and also the "special order" plague. My VIN is actually a J2H14 which is not listed in the FSM.
I'm thinking this is one of only a few available from the factory with a 401.
1972 Wagoneer
401 w/edelbrock Performer manifold and Holley Truck avenger
Complete MSD ignition system with rev limiter and billet distributor.
4inch lift.
t-18/D20
E-Z wiring kit.
Old 07-06-2009, 11:16 PM
TexTJ209's Avatar
TexTJ209 TexTJ209 is offline
You sure its an H? As that's the only part of that that's unlisted...and that digit just specifies the Assembly Plant, Transmission Type, and whether the truck was LHD or RHD.
The special order stuff was always goofy, and I've got no clue how to decode that.
'10 Chevy Silverado 5.3L - The DD.
'81 Jeep CJ-7 Laredo
'73 Jeep J2000 - On the perpetual backburner.
Texas A&M Offroad
Old 07-07-2009, 04:31 AM
hmmmm... not that far fetched I guess...
A 72 401 would have a 3 bolt pulley on the harmonic balancer.
The 74 and up V8 engines had a 4 bolt pulley.
Old 07-07-2009, 05:25 AM
What about the valve cover tag? You should have a 5mm-Z-dd build date, where mm is the month and dd is the day.
Old 07-07-2009, 08:44 AM
the valve covers were replaced
1972 Wagoneer
4inch lift.
t-18/D20
E-Z wiring kit.
Old 07-07-2009, 03:21 PM
It all fits a 72 wag except the H, you sure it's not a misread or typo'd F?
What's the 8th digit of the VIN?
Old 07-07-2009, 04:22 PM
uh60 uh60 is offline
Does your VIN 7th didget have a "Z" ?
Old 07-08-2009, 06:48 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Somewhere there must be a list of all the Special Order config rigs out there like this and the chassis mounted campers, kind of like a registry. This wag is a good demonstration of why the parts list can't be interpreted as "gospel" in defining what parts were installed on specific vehicles... more of a guide as to what was typically installed.
*** I am collecting pics and info on any factory Jeep Dually trucks from the J-Series at the new Jeep Dually Registry.
***I can set you up with hydroboost for your brakes: http://www.ifsja.org/forums/vb/showthread.php?t=106056
Old 07-08-2009, 09:08 AM
HARDCORE pacer's Avatar
HARDCORE pacer HARDCORE pacer is offline
The break on the 3 bolt and 4 bolt pulleys is 72 not 74. In the cars anyway.
78 pacer on 75 chero frame thats shortened 10\" and shackle reversal, D60 front with spool,14ff with detroit locker 4.56s in both,500 hp/500 ftlb torque 401,built 727,208 to divorced 205 doubler,on 46x21 ag tires
78 cj 360, 3spd, scout 44s with detroits SOAed with 36"tsl and beadlocks
Old 07-08-2009, 10:01 AM
OK. I did not mention 73 because I didn't know which pulley was used then. Thanks
Old 07-08-2009, 10:45 AM
dajeeps's Avatar
dajeeps dajeeps is offline
401 mystery
72 401 is not to far fetched,my 73 j 4000 on the wheel well their is a sticker saying this:engine famialy 360c.i.d and 401c.i.d. so when i repainted itthe masking tape pulled off the 1
82 wagoneer dd
73 j4000 crewcab project
Old 07-08-2009, 10:46 AM
I guess I will take a look at the pulley when I get home.
1972 Wagoneer
4inch lift.
t-18/D20
E-Z wiring kit.
Old 07-08-2009, 11:22 AM
Anything is possible regarding AMC, I've seen some weird stuff on their part.
You've got a 37yr old vehicle.
Valve cover tag/pulleys/etc. not really going to tell you anything.
Any of them can be switched or replaced over the years.
The 8th digit of the VIN will tell you what engine came in the wag.
But, the most likely scenario is that a previous owner installed a 401 @ some point.
People do it all the time even these days.
Old 07-08-2009, 03:02 PM
skeletor's Avatar
skeletor skeletor is offline
or possibly a dealer, like the brian chuchua jeeps and amcs.
-bryan
1984 j10 LWB
1977 Cherokee chief wide track(sold)
2004 LJ
Old 07-08-2009, 04:27 PM
grand_wag_85's Avatar
Murphy's Law Poster Child
I see alot of 80 and up FSJ's out here with 'factory 401's. Does the air cleaner have a HUGE yellow sticker on the driver side? What shape is the snorkel on the air cleaner compared to the hole in the valance on the passenger side between the headlight and radiator?
'65 J2000
Old 07-08-2009, 10:01 PM
Elliott's Avatar
Cowboy Up
If it has the Special Order plaque... that is there for a reason. It very likely was ordered with a 401 and there is no reason to doubt it. What else would you do to a Wagoneer in '72 that would raise it to the level of Special Order status... ? Not much.
They don't stick these in there for a hot set of plug wires:
Old 07-09-2009, 10:10 PM
ok..so it's actually not H. It's J2M144OH22....
Also, there is not really too much stock on the motor so..not air cleaner or valve cover.
1972 Wagoneer
4inch lift.
t-18/D20
E-Z wiring kit.
Old 07-10-2009, 10:51 AM
[quote=pablo_max]ok..so it's actually not H. It's J2M144OH22....
quote]
According to the H(8th digit) in the VIN it came with a 304
Old 07-10-2009, 11:22 AM
yup..you are right. I'm glad someone swapped it out at some point!
1972 Wagoneer
4inch lift.
t-18/D20
E-Z wiring kit.
Old 07-10-2009, 11:36 AM
The special sales order tag could simply mean someone filled out an order form @ a dealership vs. buying one off the lot?
Still cool though...I've never seen one on a wagoneer before.
