View Poll Results: Which of the following has been your best upgrade.
Locker 55 35.48%
Tires 17 10.97%
wheels 2 1.29%
motor upgrade. (cam, carb, intake, etc...) 35 22.58%
lift 46 29.68%
Voters: 155. You may not vote on this poll
Old 03-25-2009, 12:41 PM
They sort of all work together but like above, I didn't really consider tires and wheels as being that valuable until the rest was doing it's stuff.
1. Welded Rear
2. SOA/Shakle Flip/Steering
3. HydroBoost
Old 03-25-2009, 03:27 PM
TooRisky's Avatar
TooRisky TooRisky is offline
Wow like most, it is a combination of things...But I can rank in importance.
1: Winch, most problems can be over come with a winch
2: Lift, wheels and tires
3: Bumpers and rocker gaurds
4: Chromolly/HD hubs, axles, running gear
5: Spare parts
Man... and a million other things that make life easier off road, cb's, tow straps, tree savers, d-rings, lights, larger fuel tank, first aid kit, cold weather clothes on and on and on....
Steve...
1977 Jeep Cherokee Wagoneer, 401CID, th400, D44's, 37"MTR, 7"lift, locked F/R, York OBA,12K Warn, Lotta Love
2002 Chrystler Sebring LX DD
Old 03-25-2009, 04:00 PM
When you start with open 2.72 gears, lower gears and a locker is like taking a quantum leap in ability.
Old 03-25-2009, 05:30 PM
Merc69's Avatar
Merc69 Merc69 is offline
Best Modification
Going to Propane.
Of course I had done a bunch of modifications and the propane made the motor respond like I wanted...all the carbs I tried just did not work like expected.
Every modification is the best at the time I do it, lockers, lift, 1 ton axles, bigger tires, Hydraulic steering, Roll cage, transfer case swap and under drive. It's a growing process, I started with a rig that was someone's custom order, 3.73 gearing, 208 transfer case, bare esentials interior, Limited slip rear diff, off road suspension package...I built from there.
Merc69/ Bruce AKA G.O.D. (Grumpy Old Dude)
"PsyOp" 87 Grand Wagoneer, 360, Powered by Propane, NP-208 t-case, Dana 60 front 4.56 gears-Detroit Locker, Corp 14 bolt 4.56 gears-Detroit Locker. Alcan Springs up front, Chevy 63", Hydraulic Steering
Under Construction: 4 link rear suspension, Klune-v and Ford 205 transfer case
Old 03-25-2009, 08:05 PM
DieselSJ's Avatar
DieselSJ DieselSJ is offline
Diesel swap is not on your list. Followed closely by the hydroboost.
-87 Grand, 6.5L diesel, MHI TE06H turbo, Water/air intercooler, Art Carr 700R4, CS-130, hydroboost. 21/24mpg, dead 229 [Custom 242 on the way]
-99 XJ Limited.
-Jeepspeed 1717 -Built 4.0, FAST EFI, Rubicon Express, Bilstein, Rigid Industries, 4 Wheel Parts, G2 Axle, Currie Enterprises
-Member, FSJ Prissy Restoration Association
Old 03-25-2009, 08:18 PM
Desert Beast's Avatar
Desert Beast Desert Beast is offline
rockwells.
If it aint broke, fix it 'till it is.
Old 03-25-2009, 08:57 PM
crow223's Avatar
crow223 crow223 is offline
1. Chevy 350
2. 700r4 Trans
3. Lockrite in rear
4. xrc8 winch
77 J10 350/700r4/np208, lockrite rear, 3" Rough Country lift,xrc8 winch,33" MTZ's
Old 03-25-2009, 11:48 PM
mattmopar440's Avatar
Originally Posted by Desert Beast
rockwells.
Going a little extreme for a GW
87' Grand Wagoneer
401/727/229, Currently:RUNNING
84 J10/20 hybrid 258/727/208 Daily Driver
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 03-26-2009, 11:03 AM
Big-wagon87's Avatar
Big-wagon87 Big-wagon87 is offline
I voted lift I am runnnig a spring over front with BJ's 1" shackles and 6" springs in the back with 2" blocks and a 3" body lift.
But I think my favorite mod is my T Case I have a 203/205 doubler and I have a lomax kit in the 205.
the 44" bogger/ TSL combos are cool too.
Old 03-26-2009, 12:25 PM
jepj2000's Avatar
jepj2000 jepj2000 is offline
I said lockers for the best mod because it really brings the rest of the mods together. Then it would be tires, lift, and a winch.
Rankin
1972 J2000: 304, T18, Dana 20, Dana 44s w/ 4.09s, Rear Detroit, 7.50-16s
1977 J10: 401, TH400, Quadratrac, partime kit, Dana 60's , 4.10s, welded rear, RS44044s SOA, 63" Springs inboarded, 36" Goodyear RT IIs
Old 03-26-2009, 05:39 PM
gsmikie's Avatar
gsmikie gsmikie is offline
Auto Trannie God
wife 7.0
I\'ve seen gsmikie\'s video for the TH400 and thought it was just awful.watching a guy tear down a greasy pile of metal in a junkyard. it dosent have to be surrounded by water to be an island
Old 03-26-2009, 07:02 PM
sappy76's Avatar
sappy76 sappy76 is offline
Don't know yet, I'm doing a lot at one time. From before:
1) Lift
2) Tire
3) 360 upgrades to turn the tires
4) LSD in rear
Sucked with out brakes. Now adding:
1) Hydroboost and rear discs
2) 401
3) Fuel injection
4) 3/4 ton axles w/ 3.73s and hopefully e-lockers
5) T400/quadratrac (mostly since I want a good winter vehicle)
6) Bumpers w/ winch and tire carriers
7) Rancho RS9000 w/ remote switch
Old 03-26-2009, 07:12 PM
deadironrat deadironrat is offline
If I could only do one thing it would have to be a locker, a front locker. But since there was no way I could stop at that I now have a 6" lift, 12,000lb hydro winch, mini spool in the front, rebuilt trash-lok in the back, 360 with go fast goodies, street and strip clutch, and soon to be 35" tires. All that and I still haven't put it on the road
Jacob Z
1984 Jeep Grand Wagoneer, work in progress
Old 03-26-2009, 08:14 PM
KyooMac's Avatar
KyooMac KyooMac is offline
new wiring harness
Old 03-28-2009, 07:38 AM
Serious Johnson's Avatar
Serious Johnson Serious Johnson is offline
Ditching the silly slushbox for a T-18.
S.J.
"Carpe Mañana".
'83 Wagoneer
360, .030-over, K8600 cam, Crane springs, ported heads, Edelbrock Performer, G.M. TBI, TFI, 3" exhaust,
T-18a/208, D44/AMC 20 w/ limited slip in both, 3.73s, 33s, BDS 4" springs, Rancho 9000 shocks, etc., etc.
Old 03-28-2009, 08:07 AM
I dont have it in my J10 yet but lockers are the single best. However, I always start with the lift and tires then other small items then when funds are available I do the gears and lockers.
Old 03-28-2009, 10:53 AM
HARDCORE pacer's Avatar
HARDCORE pacer HARDCORE pacer is offline
46x22 ag tires flotation is the king in my area and with the 38s I went nowhere.
78 pacer on 75 chero frame thats shortened 10\" and shackle reversal, D60 front with spool,14ff with detroit locker 4.56s in both,500 hp/500 ftlb torque 401,built 727,208 to divorced 205 doubler,on 46x21 ag tires
78 cj 360, 3spd, scout 44s with detroits SOAed with 36"tsl and beadlocks
Old 03-29-2009, 07:53 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
That pacer has got to be king in your area also!
*** I am collecting pics and info on any factory Jeep Dually trucks from the J-Series at the new Jeep Dually Registry.
***I can set you up with hydroboost for your brakes: http://www.ifsja.org/forums/vb/showthread.php?t=106056
Old 03-31-2009, 06:48 PM
Sambo's Avatar
Sambo Sambo is offline
ON BOARD AIR wasnt on the list either...cus everyone i am wheeling with benefits from that mod
77 chero DEAD.
84wag,360,tf727,???! possiblities are d300 flipped and a ford d44 hp with coils
Old 03-31-2009, 07:55 PM
AKAMC's Avatar
AKAMC AKAMC is offline
The hot red head in the passenger seat!
06 Rubicon Wifes toy
84 CJ8
66 Amphicar Yea it's a boat too!
08 German Sheperd
03 Golden Retriever
06 Golden Retriever
19XX Sexy Red Head loaded with all the options!
ALASKA... "Land of the Individual and Other Endangered Species"
