Old 08-22-2019, 05:57 PM
Read 1st post...
Old 11-12-2019, 03:07 PM
miracleed's Avatar
miracleed miracleed is offline
this the thingy?
https://www.edelbrockspeedshop.com/E...eep_s/2079.htm
'79 Wagoneer Limited
Old 11-14-2019, 09:36 AM
Originally Posted by miracleed
No, that is the old proflo system and hasn't been made in years.
Old 11-24-2019, 05:22 PM
Full Size Jeeper's Avatar
(Read 1st post...) They must have meant the 5th quarter!! Lol.....
Old 11-27-2019, 11:37 AM
miracleed's Avatar
I sent a PM to the original poster and check the Edelbrock website from time to time... nothing yet. Holley might be calling my name.
Old 12-08-2019, 08:15 AM
SC/397's Avatar
SC/397 SC/397 is offline
According to this, it is available now.
http://theamcforum.com/forum/new-efi...26_page45.html
Pricing is out for the AMC V8 Pro-Flo 4 EFI system!
Retail price is $1895.95 and orders are now being accepted (through one of our accounts) for early Jan 2020 shipping.
First one out will be 1970-91 part # 35650, the 1967-69 # 35660 will be a little later release.
Old 12-12-2019, 12:01 PM
miracleed's Avatar
chatted with edelbrock today and they confirmed that it should be available in january. thanks SC/397.
Old 01-09-2020, 12:20 PM
Banchee's Avatar
Banchee Banchee is offline
They are available NOW !!!!
I just checked inventory and we have (5) systems left on the shelf.
We also have the EFI intake by itself #28115 for those who want to piece together their own EFI system.
91 XJ Cherokee Limited
99 Dodge Ram V10 4X4 (This thing will pull a house, but won't pass a gas station)
2010 Grand Cherokee (Hemi)
2014 Dodge Avenger SRT6 Blacktop
Old 01-11-2020, 11:28 AM
The website isn't updated with any of that information. Neither 28115 nor 35650 are shown in product searches. Better get those designer guys hot on making sure stuff is visible so we can buy it.
Old 01-12-2020, 07:54 AM
conehead conehead is offline
I just got mine from summit racing last week. It looks like a nice system but there are a couple of small issues. It doesn't include a fuel deliver system like the original Pro-Flo system did so you have to get their package, $483 at summit or make your own. Their is no baffle under the intake manifold to stop the oil from entering the PCV valve and the intake manifold gaskets that are included just cover between the intake manifold and the heads leaving the lifter area exposed. AMC used a metal pan gasket type that I think you have to use.
Old 01-12-2020, 09:36 PM
StretchinPA StretchinPA is offline
Do you have a part number for a kit without the tablet?
Old 01-13-2020, 02:01 PM
Banchee's Avatar
Several companies make fuel delivery systems, or you can piece together your own with a good high pressure pump inside the tank and a return line through the OE sending unit. Much safer then running a fuel sump under the hood!!
The intake manifold has provisions (boss's) to install the OE PCV baffle (off of a stock intake) to the underside of the EFI intake. And yes, you should use the OE style metal valley intake gasket
Old 01-31-2020, 11:03 PM
Has anyone installed this thing in their FSJ? Curious about the height and if there are clearance issues. And of course curious about the install/performance!
Looks awesome and with timing control out of the box makes me second guess getting a Sniper and also getting Hyperspark. But am wondering about the height - saw some folks who had issues but they may have been in AMC cars. Just want to make sure I can close my hood.
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 02-09-2020, 05:23 PM
If you're on Facebook this guy has it installed.
https://m.facebook.com/groups/449327...composer=false
Old 02-19-2020, 01:23 PM
acct21's Avatar
acct21 acct21 is offline
Interesting claim... particularly in light of the fact that Edelbrock was one of the first companies to bring one to market. Any data to support?
Me, I prefer to go the "unsafe" route instead of starving my high pressure fuel pump when I slosh gas away from the pickup at under 1/3 tank.
Old 02-20-2020, 09:00 AM
I'll go out on a limb here...
He is simply stating the fact that any fuel sump mounted under the hood of an FSJ is not as safe as an in-tank pump.
These things crumple up like a beer car in an accident.
Obviously having a large container of fuel under the hood isn't as safe.
Old 02-20-2020, 05:37 PM
Banchee's Avatar
You are 100% correct babywag!!!
Just because we make fuel sumps doesn't mean that is the best way to go. I do know that I would never put a plastic container of fuel and a high pressure fuel pump under the hood of my own car (no mater who makes the fuel sump)when it's more efficient and safer to have all the fuel and the high pressure fuel pump inside the fuel tank.
Old 02-20-2020, 06:44 PM
lol
I sure wouldn't even put a metal one after seeing first hand what happened with a ~35ish MPH crash did on mine recently.
Old 04-01-2020, 01:02 PM
TGrandWagon TGrandWagon is offline
Does s anyone else have experience with this? Was going to pull the trigger on Holley Sniper EFI Returnless Self-Tuning Fuel Injection Systems 550-511D but this is making me wonder..
Old 04-01-2020, 01:40 PM
I did some research on it and build quality was a little suspect since it's early. The individual injectors can lead to more precise metering and slightly more power (but more fail points?), but it's an expensive system when considering you still need a fuel pump setup beyond the dizzy and intake included with this system. The tuning interface looks top notch though.
I figure both Holley and Howell have similar products, and only Howell is 50-state approved.
https://howellefi.com/product/k247jp...eer-401-clone/
I'm still looking at the best option too though, since at some point I'll want to delete the stock dizzy, the carb, possibly the EGR (if I can -- smog requirements??), and of course go with a better breathing intake and 4bbl-type set up and coil for increased power.
At some point I'll make an excel sheet listing all my needs, what each kit offers, and what else I'll need to piece together for a full-on EFI, intake, dizzy, coil, and fuel pump set up.
crummy pics and alittle info on my jeep x6xdemonx6x General FSJ Discussion 13 01-12-2010 06:30 PM
Fort Wayne O'Daniel's Jeep Jam 2009 The PIG Smith Great Lakes 0 09-15-2009 08:14 PM
Jeep show baja General FSJ Discussion 2 09-14-2007 11:38 AM
New Chrysler- Jeep Party!! Thurs. Auburn Hills whfrat General FSJ Discussion 3 08-09-2007 09:47 AM
The Big Jeep Railroad Rendezvous 2006-CT 7/15/06 ctjeepman Events 34 08-22-2006 07:41 PM
