Old 02-27-2021, 02:49 PM
got the willys got the willys is offline
88 GW Power Seat Switch
I'm trying to get the seat switch to operate on tilt and recline. It goes forward and back just fine, so I have voltage to it.
I removed the switch from the wiring connection to clean, etc. Problem is I forgot how the two brass strips with the tabs on them go on.
I put the brass contact grid on the switch, then the insulating paper, and now I need to know how those two brass strips go on.
I did a search but couldn't find anything.
Can any body help?
Thanks.
Thanks,
Victor
88 GW
79 AMX
Old 02-27-2021, 03:06 PM
chubbinius's Avatar
There is a thread over on FSJN by Sirrus with pictures and steps to restoring his switches. Hopefully it will help you.
https://www.fsjnetwork.com/forum/viewtopic.php?f=10&t=18860&p=188616&hilit=Switch#p 188616
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 02-27-2021, 03:08 PM
Can any body help?
Thanks.
Isn't the entire switch assembly pretty much symmetrical, so really all you need to do is rotate the control 180* if the operation is backward? Pic of whatever you're describing might help.
--Rob--
My build thread:
Old 02-28-2021, 09:22 AM
Thanks for the info chubbinius. I don't see a pic of what I currently need but will be beneficial in the future, I'm sure.
Here a link to the pic. Hope it works. The switch is right side up. I have the brass plate and insulating on, and now need to put those two brass strips on.
I think they they go on the corner contacts, but not sure.
https://photos.app.goo.gl/7n6F9jQ6y6WVqaMv5
Thanks again for your help.
Thanks,
Victor
88 GW
79 AMX
Old 02-28-2021, 12:26 PM
Tripwire's Avatar
Tripwire Tripwire is offline
i probably have a working switch for ya if your interested PM me
Abort? Retry? Ignore? >
Old 02-28-2021, 01:14 PM
Thanks for the offer and all your help.
I think I just figured it out.
Thanks,
Victor
88 GW
79 AMX
Old 03-08-2021, 05:09 PM
Nope. There are different left to right. When I installed my passenger seat switch, forward and back were correct but up and down were backward. Flip the switch over and reinstall, then forward and backward were wrong but up and down were correct. I had a spare switch so I swapped switches and now there are correct. Of the 5 switches I had on hand, one was stamped "LEFT" on the housing. I don't know if that means the factory did it or someone else did it after the fact. Also don't know if the factory only marked left ones?
Wiring Power seats and seat heaters rang-a-stang General FSJ Tech 7 07-14-2017 02:15 PM
Power Seat Problem Ted21227 General FSJ Tech 2 02-22-2010 06:55 PM
Power windows switch DanHS General FSJ Tech 1 02-16-2007 05:54 PM
wiring connection for power mirror switch Jeepeta General FSJ Tech 2 08-21-2004 04:18 AM
