Old 03-29-2012, 10:13 PM
caionneach's Avatar
caionneach caionneach is offline
U-joint yoke & driveshaft question
I have the possibility looming before me of the necessity to switch out transmissions and transfer cases if my stock transmission has internal problems.
My rig is a 82 Cherokee with 258 six cylinder engine, T5 manual 5 speed, NP208 transfer case.
If my transmission is bad, & I'm pulling it tomorrow and will then know, I may opt to install the NP435 & NP205 I have. My question is about the yokes & u-joints from the transfer case to the axles, as the yoke on the NP205 appears to be a good bit beefier than the stock yokes on the Jeep axles.
I am under the impression that the Jeep yokes/u-joints are known as 1310, and those on the NP205 may be 1350. So please chime in if you know what these are.
1982 Cherokee
258 cid/T-5 $15 Sunpro Voltmeter gauge
replacement; Quadratec Trailmax Thermal Pro
Seats! 4 inch SKYJACKER suspension lift, 33X12.5 in
BFG Mud Terrain Tires on 15X10 in ProComp Rims.
New BJ's chrome-moly rear axle shafts, 3.73:1 diffs and ARB Air Locker!
Old 03-30-2012, 04:54 AM
Not sure what they might be without measuring them.
http://www.pirate4x4.com/tech/billavista/PR-shaft/
About 2/3 of the way down the page are the dimensions of the more common joints.
Lots of options out there and there are conversion joints that allow you to run say a 1310 on one side and a 1350 on the other.
I was able to get the 1410 yoke from a Dodge 205 to work on my Dodge 208 simply by finding the proper seal.
Old 03-03-2021, 01:57 PM
caionneach's Avatar
U joints
There should be no need to change out the yoke assembly in the transfer case housing.
The U-joints, however, can be adapted. The SJ Jeeps have a 1310; the u-joint on the NP435/205 combo I have, allegedly from an 80s era Bronco, is more substantial. Perhaps it's a 1350.
1982 Cherokee
Old 03-03-2021, 02:14 PM
J20 project's Avatar
hmmm, a post from 2012 mixed w/ now...
What help is needed here..? crossover ujoint, new yoke...I can do both.
J20 project.
BP Drivetrain...........
775-537-7918
Old 03-03-2021, 02:21 PM
caionneach
So, did you still need help here?
J20
775-537-7918
Owner Friendly Driveshaft? mngatewood General FSJ Tech 11 08-19-2009 08:49 AM
A question about lifts and Driveshaft Angles bashbro1 Off-Road FSJ Tech 7 11-24-2008 11:30 AM
Yoke question CRASH076 General FSJ Tech 0 10-02-2008 05:39 AM
SOA front driveshaft question fullsizejohn Off-Road FSJ Tech 10 09-02-2007 05:37 PM
SOA - Driveshaft Question Snakeyes_Tx General FSJ Tech 7 04-27-2001 07:37 PM
