  #61
Old 08-25-2015, 12:26 PM
BA_051 BA_051 is offline
Now in having an idle issue with the TBI... Was great on the old motor... It likes to stall when you pop it in neutral and back off the gas when you come to a light... But it starts right back up and idles perfectly fine... I need to mess around with my idle VE and maybe throttle follower settings...
1974 Jeep J20, gladiator grill, 12v p7100 cummins, Modified He351, 4" strait piped, NV4500/Ford NP205, 14b front kingpins, 14b rear, 4.56's, 12" lift, 37x12.50x16.5's
Old 09-20-2015, 10:11 AM
It's been a while since my last posts so here's an update...
I enabled the throttle kicker logic and disabled the error code and added about 10% to the idle VE table and no more issues!
I have 500 miles on the motor now, already had its first oil change 300 miles ago...
First and second gear are real hairy on wet/slick roads even with 3.73's and 37"s but will break them loose with ease... Sooo much more low end grunt then the 360/k8600... Pulling 7500 lbs is nothing to it now....
Now it's time for a 5 speed...
Old 01-03-2016, 11:37 PM
How's the engine running?
Do you have a thread on your 5 speed swap?
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 04-04-2016, 05:41 PM
The 406 runs awesome with the 5 speed. running at 70 mph on the highway is about 2200 rpm and never need to shift it.
I actually have swapped in an NV4500 in early February 2016 but didnt do a build or swap thread on it since it was covered so many times on many forums.
Its from a '95 GM 1 ton and needed a complete rebuild and was 2wd.
It needed a new input shaft, countershaft gear, and 2nd and 3rd gears had small chips... I put in a dodge 29 spline 4wd mainshaft, new GM input shaft, new 1 piece dodge diesel countershaft, new 2nd, 3rd, and 5th gears, all new bearings, syncros, seals, shift forks, the works. Almost everything in it is new except the top cover and parts, reverse idler, 1st gear, and the syncro hubs. Even put on a new cast iron dodge tailhousing.
I bought the advance adapters bell housing adapter to my AMC 406 and the 29 spline input gear adapter for my ford NP205. And I even re-geared my D60HP and 14B to 4.56's at the same time.
But now I am wanting to sell the 406 and swap in a 6.5 NA diesel, specifically from a 2001+ HMMWV...
Old 09-12-2019, 11:06 PM
j2sax's Avatar
j2sax j2sax is offline
406
Just out of curiosity, what was it that you did not like about the 406 that the Diesel would fix? How did it run in the FSJ?
Jesse- Sparta, MO (Near SPfdl MO) J20 4 Door Project, Wag w/ 6" Rusty's, 33x12.5's, 360/727 (for now!), 77 J10, 80 J20, 3 80's Wags, 73 Commando, Lots of AMC Eagles, FSJ parts Rigs and parts
Old 11-02-2019, 03:06 PM
jeepin87's Avatar
jeepin87 jeepin87 is offline
I bought the injection and T18 that was in this truck. I don't want to speak for him but it looks like he hasn't responded...so, he told me in person that the motor was great and he was swapping to the diesel because he wanted to try and get good fuel mileage and already had a line on the optimizer diesel. I also think he wanted to try something different, speculation on my part.
Lots of rigs, parts, and lost knowledge.
Old 11-03-2019, 05:28 AM
fsj454 fsj454 is offline
Long time member
nylon cones and springs
Hey BA 051 . I have a question . Are you running plastic nylon cones and springs on the dana 60 with 37s or are you springless TY
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Stroker 304 Project Build Greg Taylor General FSJ Discussion 204 03-31-2015 08:06 PM
Budget AMC 360 stroker build - 383 Cubes! Greg Taylor General FSJ Discussion 140 05-07-2014 02:26 PM
AMC 304 V8 Stroker Build - 327 V8 ! Greg Taylor General FSJ Tech 5 02-14-2008 06:55 AM
More stroker build questions (getting closer) IslanderOffRoad General FSJ Tech 20 05-14-2006 08:23 PM
