  #41
Old 04-12-2015, 09:45 PM
Achilles's Avatar
Achilles Achilles is offline
List of supplies and purchase locations for batter cable redo.
NOCO military Style batter terminals. Purchase from ebay, Amazon dose not have them in stock anymore.
http://www.ebay.com/itm/321713907917
10 Lot 2 AWG Ring 5/16” Hole Terminal Lug Tin Plated Copper Uninsulated Gauge.
http://www.ebay.com/itm/10-Lot-2-0-Ring-5-16-Hole-Terminal-Lug-Tin-Plated-Copper-Uninsulated-AWG-Gauge-/191353933919?pt=LH_DefaultDomain_0&hash=item2c8d95 505f
10 Lot 2 AWG Ring 3/8” Hole Terminal Lug Tin Plated Copper Uninsulated Gauge
http://www.ebay.com/itm/10-Lot-2-AWG-Ring-3-8-Hole-Terminal-Lug-Tin-Plated-Copper-Uninsulated-Gauge-/371153809554?pt=LH_DefaultDomain_0&hash=item566a7d b092
WELDING CABLE 2 AWG 20’ 10’BLACK 10’RED CAR BATTERY LEADS USA NEW Gauge Copper
http://www.ebay.com/itm/261080559404?_trksid=p2060353.m2749.l2649&ssPageNa me=STRK%3AMEBIDX%3AIT
Heat Shrink Tubing Adhesive Glue Lined 3 to 1 Shrink Ratio 12 Inch Length
http://www.ebay.com/itm/271515286379?_trksid=p2060353.m2749.l2649&var=5703 48843481&ssPageName=STRK%3AMEBIDX%3AIT
10-Ton Hydraulic Crimping Wire Battery Cable Crimper Lug Terminal Tool w/ 9 Dies
http://www.ebay.com/itm/10-Ton-Hydraulic-Crimping-Wire-Battery-Cable-Crimper-Lug-Terminal-Tool-w-9-Dies-/381220344999?pt=LH_DefaultDomain_0&hash=item58c280 d4a7
Old 04-15-2015, 05:33 AM
Achilles's Avatar
4-13-2015 was stormy and rainy day. Since I work outside I was unable to do any thing on the Wagoner.
I put together a new vent / breather with the parts from the old one and new 5/16 fuel hose.
That took all of about 5 minuets so I worked on the under hood fuse panel relay box to control any exterior accessories (The Bleepin Jeep Design as seen on youtube).
It is totally rewired so that It has 6 mini fused and 1 Maxi fused relay circuits that I can control from 7 switches from inside the cab of the wagoner. I also have 7 Maxi Fuse circuits without relays for high current circuits.
All relayed and 1 Maxi Fuse circuits accessible through a screw terminal distribution box.
Black wire is a seven wire cable that goes to the cab to connect to the switch to control relays. Yellow wire ground.
Red wires maxi fuse circuits
No carnage Today
Old 04-15-2015, 05:42 AM
Achilles's Avatar
4-14-2015
Was busy with non jeep related life things today. I Had a little time before I had to leave for work, so I put the breather / vent hose back on the rear axle.
Had it temporary capped off.
Breather valve once installed.
Attached to the axle. Connection is really solid.
Finished Product.
Today's Carnage. LOL
Old 04-19-2015, 04:16 PM
Achilles's Avatar
These past week has been a blur due to being sick. I worked when I felt ok which was not much. I will post what i have and try to catch this thread back up.
Weather was rainy this morning. So I did not do much. I worked on gluing the new visor cups up. they had a few cracks as compared to the old ones pulled from the jeep.
Old visor cups
New visor cups with small cracks glued up. Next step is to fiberglass to make them stronger and to pain interior color. (to be done at a later date)
Made new breather / vent hose for front dana 44
Weather cleared up this afternoon and this was sitting on my desk.
Old sensor location.
Old sensor removed
New Sensor installed
No carnage picture for the day, but I did snap this!!!!
Dinner!!!!
Old 04-19-2015, 05:48 PM
Achilles's Avatar
I received a dash pad I purchased from one of the forum members.
This was really packed well!!!!!
The dash pad is 200% better than the one that is currently in my wagoneer. I will dye it to the proper color when the time gets here.
Old 04-19-2015, 06:04 PM
Achilles's Avatar
Front Dana 44 service and new Breather/vent hose install.
Gears are good, looks like the PO used the same clear house silicone to seal the diff cover as he did on the transfer case. Minimal sludge in bottom but fluid was way darker than the rear axle. You can se a string of the silicone hanging down from the top on the left side of the picture.
This axle has 3.31 gears in it.
All buttoned back up.
Added the gear oil.
Removed old and installed new breather / vent tube. Wow, This is dust season in Texas and it gets every where. Time to wash the motor and engine compartment.
Made it a tad bit longer, so i can place it where I want later.
Today's carnage.
Beware the gasket for a front Dana 44 that most parts stores will sell you is not the one you need for the 83 and up with the vacuum disconnect axle. I had to use Ultra Black RTV which I had on hand. I have a Dana 44 gasket if anyone need it at a fair price.
Old 04-19-2015, 06:31 PM
Achilles's Avatar
Steering Stabilizer
The steering stabilizer plate on my wagoneer has been broke since I have owned it. I purchased one from a member on this board. Cleaned it up, painted it and put it away. I was reluctant to mess with the u bolts and axle because it has been out of my comfort zone. After discussing it in a thread earlier in the week I decided what the heck I am just going to do it and take pictures so I can get it back together right. When I let the jack down after disconnecting everything and putting a jack stand under the frame; I flipped when the axle sunk almost to the ground. I took a deep breath and started working.
Broken steering stabilizer and plate.
You can just see the broken connector plate under the perch.
I had soaked the U bolts and stabilizer bolts in PB Blaster for the last couple of days. The stabilizer came off easy.
The u bolts fought a little and then came off. I disconnected the shock and the sway bar end link, placed a jack stand to support the frame. Lowered the jack. The spring sagged more than I expected it to. I got the jack under the axle tube and it separated from the springs.
Broken stabilizer plate.
What have I done. Deep Breath.
Today's Parts
Put the plate in and reversed everything I had done before this. and got the u bolts back in and everything sort of lined back up.
Buttoned back up.
Everything installed!!!!!
Today's Carnage
Not to bad for the first time doing this.
Old 04-28-2015, 07:39 AM
Achilles's Avatar
Talking Why these rigs are so awesome!!!!!!!!!!!!!!!
Owning one of these rigs is not cheap and can be super frustrating at times but it is awesome entertainment. Even a bit addicting. It is weird how they almost become like family mascots or almost like pets. My oldest was home from college this past weekend and came out back to see me. You should of seen the smile on her face when she realized that the Wagoneer was running. Even my wife who hates outside with a passion came out to see Achilles. She even helped me remove the tailgate regulator and glass after I had a Jeep induced mini melt down. We had bad weather the past couple of days, and I could not get anything done since I work outside. More Updates coning soon.
Old 04-28-2015, 03:33 PM
Achilles's Avatar
Today's Parts
Getting ready to drain antifreeze.
Draining
I popped the thermostat out in it was a 160 degrees F thermostat. What the heck and why was it in here. no wonder engine would never come up to temp.
All laid out and ready to install.
Only had one minor problem geting the the heater hose that connects to the water pump back on. I partially disassemble the alternator bracket. to get it on and tighten the hose clamp. All finished up with hoses.
Belts on.
Today's Carnage
Old 04-28-2015, 03:36 PM
Achilles's Avatar
Changed the oil to 15W-40 Today. Decided to give it a try. The 10W-40 looked a little thin.
Today's Carnage
Old 04-28-2015, 03:39 PM
SIUADOG's Avatar
SIUADOG SIUADOG is offline
Loving this write up, especially the carnage photos. A big bag of trash (and no ruined parts) at the end of the day gives a feeling of accomplishment.
Just Empty Every Pocket
1988 Grand Wagoneer
AMC 360
727 TF
No modifications so far... Yeah, I'll probably keep it stock.
Old 04-28-2015, 04:14 PM
Achilles's Avatar
I put a quart of Rislone in the oil.
I decided to bolt the drivers side seat back in so that it would not be quite as precarious moving the waggy around.
I decided that I need to adjust the power seat. I crawled in to the back to make sure all the tailgate wiring were still disconnected before I put the breaker back in. I decided since I was back there I would take a drill battery and lower the window. I touched the wire to the battery and it went a third of the way down and stopped. Crap, now I am side tracked. It would not go up or down. Off came the latch cover and key switch body.
I wedged my hands in behind the regulator and took the 3 bolts out of the motor with a 7/16 wrench. I pushed the window down and removed those dreadful clips. After having a melt down. My wife helped me get the window and regulator out.
Off comes the tailgate switch. Yep, it is broken for sure.
What in the Heck have I done.
I discover as I am cleaning up the regulator that I am possibly missing three stand offs. After another mini melt down. I realize there is no way I am getting this back together today. I have to try and locate the stand offs and dig the parts I ordered from BJ'S for the tailgate out of storage. I have all the seals and parts, but had not planned to do this until after I had the waggy running solid, safe, Inspected and registered. I vacuumed all the junk out of the tailgate and washed it out with a hose. I lubricated the gate mechanisms so it would close properly. I pulled the waggy back to its storage space and went and purchased a bigger tarp to cover it up since it no longer had a rear window.
Today's Carnage
Unintentional Carnage: 1 rear tailgate window
And as luck would have it we have had thunderstorms for the past three days. I just had to move the power seat!!!
To be continued.
Old 04-28-2015, 04:27 PM
Achilles's Avatar
Thanks for coming along on the ride. It is my first attempt at doing something like this so I am learning as I go and loving every minuet of it.
Old 04-28-2015, 04:58 PM
DieselSJ's Avatar
DieselSJ DieselSJ is offline
Great idea on fiberglassing the visor cups. I'm going to give that a shot.
-99 XJ Limited.
Old 05-05-2015, 01:26 PM
Achilles's Avatar
Still working on tailgate and window.
Today's Parts!!!
Started by removing upper window track in the body.
All gone
This is what was left of it. Over 2/3 of it was missing.
New one installed.
Time to remove the body sill. It was in good shape but really compressed.
Old 05-05-2015, 01:30 PM
Achilles's Avatar
Today's Parts!!!
All gone
New one installed.
Also remove these two small square bumpers.
Bumpers and seals off.
New one installed.
Old lisc plate light and replacement.
To BE Continued!!!!!
Old 05-05-2015, 01:45 PM
Achilles's Avatar
Decided to fix the front passenger and driver side door jamb switch.
Modified switch.
Installed!!!
Old 05-05-2015, 01:47 PM
Achilles's Avatar
Now on to the tailgate inner slide channels. The old ones were really eaten up and hardly had any felt left on them. Straight forward easy install.
Testing the safety switch after cleaning.
Back in.
Old 05-05-2015, 01:58 PM
Achilles's Avatar
Starting the Tailgate harness install.
New Switch is in.
Installed with new gasket.
Back together.
Once again I have some pictures that did not come out well. Here is the only one of the tailgate window channel refurbish and refinished.
To be continued.
Old 05-05-2015, 02:23 PM
SJTD SJTD is offline
What was the mod to the door jamb switch? I've read that available switches don't fit. Haven't started looking yet.
What's the box on the plate next to the relays for the window?
Looks like you need a cover for the tailgate key switch too.
Sic friatur crustulum
1983 Wagoneer Build Kansas_Nova General FSJ Tech 69 12-24-2015 06:09 PM
1983 Wagoneer: Which non-Jeep OEM bucket seats work well? Jake Spoon General FSJ Tech 9 09-10-2012 09:52 PM
1983 wagoneer brake contoller? NYK General FSJ Tech 3 12-06-2009 07:09 AM
Final drive ratio, 1983 wag... ????????????? Karl Streich General FSJ Tech 1 02-05-2005 04:56 PM
