Old 04-04-2015, 05:33 PM
Achilles's Avatar
Achilles Achilles is offline
As soon as the 100 mph wind dies down I will get the cover off and snap a whole Wagon pic.
Old 04-05-2015, 12:09 PM
Heep-J4000's Avatar
Originally Posted by Achilles
Vitamin water and rubber hose to the rescue. That is not the color of the vitamin water, that is the nasty old break fluid.
I have to admit that im also a bit addicted to brake fluid
but don't worry i can stop anytime if i want!
Achilles a helper is always a nice thing to have!
And you making some good progress with the repairs
i wish we could get (jeep) parts that easy at the carshop!
Old 04-06-2015, 07:59 PM
Achilles's Avatar
Not so Good Picture of the Wagoneer.
Old 04-06-2015, 08:02 PM
Achilles's Avatar
Had a half day of vacation. I came home and had the rear tires mounted.
Mounted them up, just need to put the center cap back on them.
Old 04-06-2015, 08:07 PM
Achilles's Avatar
Removed the old broken starter and went back to town and grabbed a starter and solenoid.
The gear was really chewed up but the flywheel was ok.
Installed the starter and solenoid no problems encountered.
Old 04-06-2015, 08:12 PM
Achilles's Avatar
I had ordered supplies a while back to replace terminals and cables.
Also purchased this hydraulic crimper.
Strip Wire
Insert in proper lug for application and place in crimper. pump the handle to crimp.
Finished crimp
Finish off with heat shrink with heat activated glue.
I made all the positive and negative cables this way.
Old 04-06-2015, 08:16 PM
Achilles's Avatar
New Terminals. I really like these. plenty of room to add positive and negative accessories.
Wiring up solenoid.
Finished product.
Today's Carnage.
Now it starts on the first turn of the key.
Old 04-07-2015, 12:09 PM
DieselSJ's Avatar
DieselSJ DieselSJ is offline
Strip Wire
Finished crimp
Nice. Only critique is that you should have run the shrink tube over the end of the crimp. Looks like you just butted against the end of it. You want to actually seal the joint. I see that you did it with the positive cables. Is that just an optical illusion with the negative cable?
-99 XJ Limited.
Old 04-07-2015, 12:40 PM
Achilles's Avatar
It is over the crimp and part way up the lug. It is just hard to tell because the heat shrink tubing is clear. They were out of black when I ordered. I should of gotten a better picture of it.
Old 04-07-2015, 12:56 PM
SJTD SJTD is offline
Where'd you order the electrickery?
Sic friatur crustulum
Old 04-07-2015, 01:46 PM
BigOberg's Avatar
BigOberg BigOberg is offline
oh i wish i had a cool handle.......
It looks really good! Looks like I just added another expense to my build!
Follow my build http://www.ifsja.org/forums/vb/showthread.php?t=174682
1989 Grand Wagoneer: 360-727-229, 4" BJ's Lift w/32's, Howell Fuel Injection, TFI Conversion
Old 04-07-2015, 03:35 PM
DieselSJ's Avatar
Ahhhh. I see it now.
-99 XJ Limited.
Old 04-07-2015, 05:24 PM
Achilles's Avatar
Got every thing off of evilBay including the crimpers.
Old 04-08-2015, 04:11 AM
Atla's Avatar
Atla Atla is offline
I really like those terminals, I need a set for both rigs.
~Atla.
My '83 J-10 Rebuild
Old 04-08-2015, 06:45 AM
Achilles's Avatar
Military Style Top Post Battery Terminal.
http://www.ebay.com/itm/Military-Style-Battery-Terminal-1-Set-Pos-Neg-Ships-from-Canada-/171540093316?pt=Motors_Car_Truck_Parts_Accessories &hash=item27f0961984&vxp=mtr
I purchased mine from Amazon but they do not seem to have them in stock. they are a lot more pricier on evilBay.
Old 04-08-2015, 02:07 PM
Achilles's Avatar
Short video compilation of the past few days work!
https://www.youtube.com/watch?v=HIuIL-SdHlw
Old 04-12-2015, 07:51 AM
BigOberg's Avatar
No wonder you had such a hard time with starting. You're starter was a 4x4 Anyway I'd love to see your parts list for the cables. If you have a chance please post it or PM me. Keep up the good work!
Old 04-12-2015, 09:02 PM
Achilles's Avatar
Yes, I will get one together and get it posted.
Old 04-12-2015, 09:18 PM
Achilles's Avatar
4-11-2015
Spent a little to much time indoors procrastinating this date. Decided to tackle fixing the broken vent tube issue and do a rear diff service on the AMC 20.
Supplies for today's work.
Vermont American 1/8 x 27 Tap w/ handle and Moller 1/8" NPT X 5/16"hose barb fitting. O'Reillys auto pars has this fitting as well as amazon.
Hose barb that would not stay connected and is being replaced.
Breather hole on drivers side of rear axle to be tapped. notice no threads, appears to me a press fit with old fitting.
A little grease on the Tap to catch the fine fillings.
Tapping the hole.
Sorry for the bad picture, but you can just make out the new threads in the breather hole.
New fitting screwed in place. Worked like a charm!!!!!
First Project Done!!!!!!!
Old 04-12-2015, 09:29 PM
Achilles's Avatar
Amc 20 Diff Service.
Filler hole on drivers side front of pumpkin.
Dirty Diff cover with grease filled bolts, be careful and clean them out or you will strip the torx head of the bolts.
Screws out and draining.
Everything appears to be ok inside the pumpkin.
New cork gasket and Lion Gasket sealant w/ freshly painted cover. It is all sealed back up.
Today's carnage.
Break Cleaner, Cork gasket, Gloves and Shop Towels.
1983 Wagoneer Build Kansas_Nova General FSJ Tech 69 12-24-2015 06:09 PM
1983 Wagoneer: Which non-Jeep OEM bucket seats work well? Jake Spoon General FSJ Tech 9 09-10-2012 09:52 PM
1983 wagoneer brake contoller? NYK General FSJ Tech 3 12-06-2009 07:09 AM
Final drive ratio, 1983 wag... ????????????? Karl Streich General FSJ Tech 1 02-05-2005 04:56 PM
