  #321
Old 10-07-2013, 02:56 PM
CJ5 CJ5 is offline
Sorry, guys about the final update. I have been working on getting all of the bugs out and didn't want to do a final update until it was really finished.
The motor is strong and have no issues except fine tuning. I have a spreadsheet started and noting all changes and results. I am trying to get it perfect. I have changed jets, rods, mixture, etc. At the same time, I am noting mpg and what each change has done there. I have not touched the timing but will be doing that also. We have been driving it everyday since we picked it up from the shop. I just wanted to tinker with it more to get it perfect. I am almost there. It is running smooth and is at 10.3mpg. I think with some timing adjustment I can get a little more quickness and a little more MPG. I can live with anything above 10.
I had issues with the AC switches. First was the thermostat, then the fan. I waited on some used parts only to find the fan switch was different. I installed a new thermostat switch. The fan switch will only blow on high so until I can find a rheostat that will work I will have to live with it. The drain nipple was broke and it appears my fix didn't work so I am trying to find a solution for that so the water doesn't leak onto the carpet.
Dash LED strip has shorted somewhere. Not sure how or where. I have to removed the instrument panel to fix. Of course that means taking the steering wheel lose enough to drop it some. This is unfixed as of yet.
I had a issue with the alt. but that turned out to be a bad crimp on a wire. Other than electrical is fine and show no issues except the cheap arse loom as shown signs for degrading in high heat areas.
My windshield is leaking at the passenger bottom corner. Same place it was before the rebuild. I am looking for solutions there but have made some stop gap measures to keep the carpet dry. Gasket problem likely.
The brakes were not as good as they needed to be for a 16 yo driver and I worked on those. I found I had one side of shoes in wrong and fixed that. I replaced the master cylinder. The one I originally put on there never did seem like the right one to me. Then because of such low vacuum, I replaced the booster to a dual diaphragm and that made the biggest difference. I did not want to mess with hydro.
Last night I had to go back in the door and replace the clip for the regulator. I should have did the retro fix on the doors and didn't. I did do it for the tailgate. If I have to go back in there I will pull the regulators and upgrade.
I have one slight oil leak around the filter. It appears to be the lower piece on the oil pump assembly around the pressure spring. I think I can remove it and just put another gasket or sealer without getting into a big deal. Only leak so far.
Other than those and a few odd issues it has been about as expect. I knew there would be some odd and ends.
Oh....he cut it too close getting in the garage and scraped the rear fender flair against the bricks. I have to sand, bondo and repaint it.
Chief Laredo Build Album:http://www.fototime.com/inv/BB4AF31A10748CC
'72CJ - Complete Restore
'81SJ - Loredo Resto Project
'91YJ - Rock Crawler
Old 10-07-2013, 05:38 PM
8man's Avatar
8man 8man is offline
That is his truck now, have him do it with you and tell him "this is the last time I help, it's your now." Great to hear the final report, seems like a long way off to me right now.
Old 10-07-2013, 05:40 PM
WHSII's Avatar
WHSII WHSII is offline
Hack-Priss
Sounds grand Sir,
Please post some pictures of the rolling Cherokee, I know that you want to have it all complete, but people are hanging waiting for them!
Pictures will not show that the timing is off by 1/2 degree!
Again Sir, Salute, job well done.
WH
Herbina 1987 Grand Wagoneer
Old 10-14-2013, 12:09 AM
polarfire's Avatar
polarfire polarfire is offline
Originally Posted by WHSII
Sounds grand Sir,
What he said!
'78 Cherokee Levi's 4-Door
'84 J10 Shortbed
'83 Cherokee Chief
'82 CJ-8 Scrambler
Old 04-25-2014, 07:23 AM
donniesoup donniesoup is offline
I just read through this again. It is one of the most detailed rebuilds here. Outstanding. Can you post the completed photos for us?
80 chief wt
94 cherokee
11 liberty
Old 06-09-2014, 10:34 PM
polarfire's Avatar
Any update on this build? I would love to see the finished product!
'84 J10 Shortbed
'83 Cherokee Chief
'82 CJ-8 Scrambler
What's a SUPER Chief - OLD TOPIC MESS UP...REPLY HERE! testuser General FSJ Tech 10 12-06-2015 11:10 AM
interested in a Cherokee Chief. MisterKeith General FSJ Discussion 11 11-12-2009 07:18 AM
1981 Cherokee Laredo - Tom Anhalt Dome Cherokees 0 08-21-2005 12:36 PM
Mission: Restore 1977 Chief Boogie77 General FSJ Tech 1 02-13-2003 08:30 AM
My New 83 Chief - Help needed arbi General FSJ Tech 9 02-20-2001 02:59 PM
