Closed Thread
  #81
Old 03-02-2013, 06:09 PM
csuengr's Avatar
csuengr csuengr is offline
My 77' WT Cherokee.
http://www.ifsja.org/forums/vb/showthread.php?t=134070
If at first you don't succeed, use a bigger hammer.
  #82
Old 04-07-2013, 09:36 AM
78WideTrak's Avatar
78WideTrak 78WideTrak is offline
1978 Jeep Cherokee Wide Track
AMC 360
GM Turbo Hydramatic 400
Quadratrac
Dana 44's front and rear
PRETTY sure there is a rear locker (both tires spin both directions when off the ground)
Fixed leak in Quadratrac
New Sway Bar Bushings
New Power Steering Pump
Edelbrock 650
Edelbrock 14" Air Cleaner
New Alternator
New Starter (Twice- Get the lifetime Warranty from O'Reilly's)
New Plugs
Replaced all parts inside the Mallory HEI
Re-wired the ENTIRE Jeep front to back with a Universal Kit
Rust Repair/Removal
Bedliner on Interior
Bedliner on Lower Rockers
Painted Behind Grille
New Headlights with Intergrated Turn Signals (Came with Jeep, Installed while re-wiring the whole thing)
Les Schwab XT 700 Cold Crank Battery
Replaced Tape Deck that Came with to an Alpine CD w/ iPOD Plug
Toyo Mud Terrain 33x10.5-15 Tires
http://www.ifsja.org/forums/vb/showt...=1#post1530979
78 Cherokee W/T. 360/TH400/ QT and D44's. Toyo M/T 33x10.5-15. Edelbrock 650, Mallory HEI, FULL re-wire.
  #83
Old 03-18-2014, 05:38 AM
Strode's Avatar
Strode Strode is offline
1st Chair, Cowbell
1982 Cherokee Laredo.
Fall of 2011, before:
[/quote]
May of 2014:
Build thread is here:
http://www.ifsja.org/forums/vb/showthread.php?t=157145
Ristow's Bunker
  #84
Old 03-18-2014, 07:37 AM
ProTouring442's Avatar
1989 Grand Wagoneer "Daily Driver"
2008 GM LY5/4L65E swap
Custom A/C solution
Custom dash
Suburban 42 gallon tank
Soon to start: Wide Track conversion
http://www.ifsja.org/forums/vb/showthread.php?t=165696
  #85
Old 03-18-2014, 02:29 PM
Dustin Langston's Avatar
Dustin Langston Dustin Langston is offline
Noob!
My build thread; 1982 Wagoneer Limited
Here is a link to my build thread on fsjnetwork. It is a full restoration including a 5.3 Vortec swap with 4L60E. It has been a lot of fun and the work is winding down now. I am just finishing up door panels and that will be the end of it.
http://fsjnetwork.com/forum/viewtopic.php?f=12&t=4400
Closed Thread
