Old 03-28-2012, 04:27 PM
mattparliament's Avatar
mattparliament mattparliament is offline
Would valve covers from an 89 360 fit my 76 401?
Quick question:
thanks guys!
MP
1976 Cherokee 401 Quadratrac
4" Rough Country Spring lift 31" tires
All MSD ignition system
EZ EFI status: Running Smooth!
Dakota Seats
Powertrax No-slip lunchbox rear locker
Amp meter delete
Two Wire 94Amp Alternator upgrade
Old 03-28-2012, 04:30 PM
derf's Avatar
derf derf is offline
360 AMC
Yes. The 290/343/390/304/360/401 all use the same size valve covers.
Try out my gear ratio calculator
Old 03-28-2012, 04:49 PM
yeah they'll fit. I do suggest keeping/transferring the correct eng build code tags with correct engine.
perfect, thank you!
Dakota Seats
Amp meter delete
AMC 360 flexplate on a 401??? FSJ Guy General FSJ Tech 15 05-20-2015 08:21 PM
360 TO 401 SWAP Stu General FSJ Tech 5 05-13-2010 03:13 PM
Swap a 401 from a 360 Blake General FSJ Tech 15 09-12-2006 08:15 AM
4BBL 360 carb& intake on 401? grand_wag_85 General FSJ Tech 3 05-29-2006 11:19 PM
Found a 401, now what will swap off my 360? KYJ10 General FSJ Tech 3 05-19-2003 02:29 AM
