Old 04-09-2009, 08:12 AM
The PIG Smith's Avatar
King Browless
Nice posting...great information...
<mini-hijack>
While I may have the skills to modify a carb meant for a small block Ford, I do not have the experience.
I am looking to make my J10 a semi DD with some trail riding from time to time.
What off-the-shelf 4BBL carb would you fellows recommend?
I was thinking of either a Holley Truck Avengeror but thought myabe that would be overkill for mostly street use.
...or would someone like to mod one of these SBF carbs and sell it to me?
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 04-09-2009, 09:52 AM
truck avenger is a very good carb. spendy too. you can get a 4180 ,put a kit in it with a new throttle shaft for 75-100bucks.
i'd do one up for you. would not have the secondary block though,unless you bought 2,i have no spare blocks.
Old 04-09-2009, 10:23 AM
smearig's Avatar
smearig smearig is offline
<mini-hijack>
My Edelbrock 1406 seems to be working fine and all I had to do was adjust the idle out of the box. My friend has a brand spanking new 670 Truck Avenger for sale if you're interested.
1983 WT Cherokee
2003 Ram 2500
2003 Bandit 1200s
Old 04-29-2009, 06:01 PM
Some advanced tuning.
well,after spending some time playing with the jetting,i found myself stuck choosing between 2 jetting scenarios',and i didn't like either.
i've seen 3 different #'s on the jets in these 4180's. 209,309 and 602. 602 is supposed to be a close tolerance #60. i assume the other 2 numbers are fords numbers for the same jet. problem is,a 60 main jet should have a .060" hole,and these are considerably smaller. a couple thou' smaller,which is a lot relatively speaking.
with the stock jetting,it cruised ok,slight surging. and it pinged when i got into the gas,and it lacked the punch when i really stepped into it. but it got real decent mileage.
so i stepped it up several sizes on the mains,and the punch returned. the pinging stopped too. the mileage ceased as well.
so,as it was i had 2 choices. good mileage with poor kickdown punch,and needing to retard my timing to avoid ping,further decreasing power. or,jet it up to have power,and losing economy.
i wanted the best of both worlds,and here is how it is done.
the main jets are what you cruise on. that is why jumping up on them killed my mileage. i drilled a set of stock jets out with a .059 bit,making a #59 main jet and installed them.
the fix lies in the PVRC's. Power Valve Resriction Channels. they are behind the power valve. these are the "second" set of jets that are allowed to deliver fuel when the power valve opens.
i measured the PVRC's on a couple metering blocks i had around,from 600 and 750 cfm holleys. they range from .051 to .063. so,that means when the power valve opens,it's like having a second et of jets,sized 51 to 63,on top of the main jets,supplying extra fuel to the mix.
then i measured the 4180 block. they looked large. too large. a peak inside showed they were counter bored,and considerably smaller inside. to the tune of about .040. it's hard to see in the pic,you can barely see it. the inner hole is about half of the visible hole.
the fix is to open up the PVRCs',changing only the power jetting,not the cruise jetting.
i opened the PVRC's up to about .045-equal to about 4-5 jet sizes over the stock .040 holes,and the punch returned,and the pinging stopped,allowing my timing to be set to it's optimum setting. economy returned too. i'm getting consistent 13.5+ mpg. i'm going to jump up a bit more on the PVRC still though,.048-.050. it'll need it when the headers/dual exhaust go on.
this is the one and only place the Carter AFB design offers tunability over the holley. however,i want to stress this procedure is RARELY NEEDED on a holley. this carb was an emissions carb,hence the small channels. all you guys running universal holleys,like the 1850,3310,or avengers-DO NOT TRY THIS! it is almost 100% not needed in those models. once this procedure is done,you can't easily go back.
Old 04-29-2009, 06:53 PM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
Great write-up! What is the best mileage you got during this process? What is your technique for drilling. I've never tried because I've been told such bad stories about drilling out jets.
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Old 04-29-2009, 07:13 PM
13.6,according to my odometer,which i'd call a 13.5 overall average. keep in mind this is a mildly built stroker,with oversize valves and a tad overcam'd with rhoads lifters.not really a fuel efficient build,so at 13.5 i'm real happy. i drive it rather easy,but even driving easy it's fun,the torque is strong even then.
i used my dremel,which worked well,considering the angle it's at. a hand arbor would be ideal i s'pose,but a bit tedious,and since this is the enrichment circuit,it don't gotta be real precise. main jets are easy on the other hand.
