Old 07-05-2022, 12:18 PM
cabz cabz is offline
4.2 to 5.9 engine mounts and engine placement
Hello.
I have an 81 i10 that used to be a 4.2 4spd truck.
It was hacked into a 5.9 4spd and I mean hacked.
My question is I want to correct the hack and go 5.9 727.
Do I have to change the frame mount brackets for the 5.9?
And what holes/ do i use to mount the trans crossmember?
Jeep rich, Cash poor.
Old 07-06-2022, 10:27 AM
Originally Posted by cabz
Hello.
Have you located a donor for the 360/A727? I would just copy what I found in the donor. There are many differences between the I6 and V8 vehicles - this has been covered a lot in previous post on this forum. You can search with Google or other online search engines and find plenty of reference material.
https://www.bing.com/search?q=site%3...360+conversion
There are parts books on the Tom Collins sites that will confirm the difference in the frame towers for the 6 and V8. Again, find a donor for what you need online with a site like car-part.com, or advertise in the WTB forums here and at other Jeep sites. You could also look for parts cars in the for-sale forum here and at other Jeep forums.
Old 07-06-2022, 07:23 PM
backroadin''s Avatar
Did the hacker change the frame mounts? If not, the correct v8 frame horns will be different - yes.
Not sure on the frame holes for the tranny x-member, but if you mock it up it should be obvious. My guess would be the rear ones since the auto tranny is longer, but it really depends on where the mount mounts on it. If you're changing / welding in new frame horns, then you can position them to use whatever set of holes you need to.
Good luck with the project!
What engine mounts to use? ZackN920 General FSJ Tech 6 08-28-2021 02:00 PM
cherokee 360 engine mounts and engine install ? jabbawaki General FSJ Tech 12 11-02-2011 10:14 AM
6.2 engine mounts smacmoyle General FSJ Tech 4 05-24-2008 04:03 PM
Engine Mounts...Poly vs Rubber YoungClayB General FSJ Discussion 9 04-19-2008 06:56 PM
V8 Engine Mounts TINMAN93 General FSJ Tech 7 09-16-2006 09:06 PM
