  #41
Old 05-04-2021, 11:23 AM
That's awesome! I love it when folks just "make it work" like that!
Old 05-06-2021, 08:02 PM
scout4bta's Avatar
scout4bta scout4bta is offline
One more connector, The Dorman 645-1000 does fit although it's a little loose but it does lock in. It will require some weatherproofing.
Did find that NAPA EC1456 $40, is supposed to be a direct fit, but I'd already ordered a dorman 645-1000 for $10, the EC11 was $15.
1989 GW/91.5 Dodge W250 CTD flatbed/ 06 Ford Crown Vic Police Intercepter/05 Jeep Liberty Diesel.
Old 05-07-2021, 02:32 PM
scout4bta's Avatar
4BT hooked up to the trans and Tcase for a test run
Click on the picture to start video
4bt run with trans and tcase DSCN2936 by , on Flickr
No leaks, no strange sounds or vibration. Guess I got the shift kit in OK.
Old 05-07-2021, 08:29 PM
WHAT?!? No video?! I do not think it really ran...
Is that an atlas xfer case?
Old 05-07-2021, 10:07 PM
scout4bta's Avatar
Video works for me, Click on the picture or the text at the bottom of the pic. If that doesn't work try this LINK
Yes Atlas 3:1. Only the best for the SJ.
Old 05-10-2021, 10:59 AM
DOH!!!! I didn't even see the link! I see it now. That's awesome!!! sounds healthy! Your truck is going to be a great driver!!!
Old 05-10-2021, 02:19 PM
scout4bta's Avatar
Actually I added the text link later, not your fault. Flickr used to have a link that looked like video, now it just looks like a pic.
Had plans today to put the engine on a makeshift stand and run it at speed to test the 3000 rpm governor springs I installed.
Got the engine moved to the door and the engine lift gave out. Bought it in 1987. A new 8 ton long ram is on order, should be here next monday. Oh well need to tidy up the shop any way.
Old 05-11-2021, 12:11 PM
scout4bta's Avatar
Curb Weight
Ran the 89 GW over the scales, 4600 lbs. Thats with a full tank of gas.
weight on the Front axle, 2400 lbs, weight on the rear axle 2040 lbs.
Old 05-14-2021, 04:38 PM
scout4bta's Avatar
Had time to weld up the right side engine mount with some left over 3/8" plate.
Old 05-15-2021, 08:06 PM
SJTD SJTD is offline
What are the mounts from? The rubber thingies, not the metal?
Sic friatur crustulum
Old 05-15-2021, 08:41 PM
scout4bta's Avatar
I don't know the application but the brand is Anchor 2698 mounts. They must be mounted vertical as shown
Old 05-15-2021, 10:35 PM
That'll work for me. The question is will they fit. Mine're oval and those might be wider but I'll do some checking.
My mounts are from '80 so 40 years old.
Thanks for the lead.
Old 05-16-2021, 07:50 AM
scout4bta's Avatar
Just reread your signature, I know the SD33T well. My Scout came with one, unfortunately when I bought the Scout the engine was on it's last legs. Ended up swapping the engine for a 4BT.
The mounts are called "Fluidlastic" mounts. The ones I have are 3" tall and 4.2" wide on the bottom with 13mm studs.
Old 05-18-2021, 02:12 PM
scout4bta's Avatar
The Left side engine mount:
Old 05-18-2021, 09:32 PM
When you get a chance can you measure the big diameter, approx? The Anchor site say 6 7/8". Doesn't look that big from here in your pics.
Thanks.
Old 05-18-2021, 10:11 PM
scout4bta's Avatar
Thanks.
I measured both height and width with calipers. That's measured from the top and bottom surface not to the top of the studs.
edit, here's a link the the applications late 80's, early 90's Ford Bronco
Old 05-18-2021, 10:45 PM
So what did you get when you measured? Or are you agreeing with Anchor's published dimensions? I saw the application data on their site.
Old 05-19-2021, 11:18 AM
scout4bta's Avatar
Let me restate my measurements, the height is approximately 3", the width is approximately 4", + - .05", excluding the studs.
The published date from Anchor is for the shipping BOX, not the item.
Old 05-19-2021, 12:28 PM
Woohoo! I think it'll go. And if they don't, Anchor makes similar mounts with smaller shipping dimensions so presumably the mount is also smaller. And they're cheap enough to take a chance whether or no.
I'll have get away from the kitchen remodel to take a peek.
I see now you posted the dims several posts up. Reading comprehension fail. Sorry about that and thanks for your patience.
Did the Scout use the flywheel housing mount? The front mounts are way forward rather than the more or less center of the motor like on most vehicles so the little rear mount would take a lot of weight. I used the housing mounts too.
Thanks again.
Old 05-19-2021, 04:04 PM
scout4bta's Avatar
Thanks again.
The Scout engine mounts, are talking about the original SD33T or the 4BT mounts? The SD33T in the Scout was factory. For the 4BT mounts I used 93 Dodge Diesel mounts with custom engine mounts I made.
Bad stumble on acceleration coming home last week- fixed!! Dirtball General FSJ Tech 12 04-20-2009 09:48 AM
Headed to montana...19+ hours UPDATED home with story orangebike General FSJ Discussion 11 04-12-2009 10:24 AM
Home again RiverRat Ouray FSJ Invasion 6 07-17-2007 12:53 AM
The Chero is home, and now it's running nicely... DanHS General FSJ Discussion 20 02-21-2007 07:10 PM
Tomorrow is Time to bring home my '79 Cherokee! DanHS General FSJ Discussion 23 02-14-2007 11:09 AM
