Old 01-16-2020, 09:36 PM
maybeadinosaur maybeadinosaur is offline
Puddle in the floorboard!
...not the usual suspect though! This puddle is only in the rear passenger floorboard. I had the usual roof rack leak a few years ago and replaced most of the gasket/plugs. I no longer see any dripping headliner issues so I'm 99% certain the rain water isn't getting in from there.
The water does reach over to the door, right where the carpet meets the metal flashing so I suspect water is running down the area between the door and the body, pouring into the original weather stripping (it has some holes in some places), which is acting like a funnel or straw.
Has anyone else run into this issue? Is there a chance that the rain water is getting past my roof rack gaskets and running down a channel in the pillar between the front and back doors?
Old 01-17-2020, 01:04 PM
asphaltrockdweller's Avatar
There are SO MANY places where water gets in to our FSJ's.
On the Wagoneer's that I have had (still have), all three of them had stress rips in the sheet metal around the rear wheel wells. The most common tear in my Waggy's is at the rear of the rear door where the floor board goes up to the cargo level.
When I stripped down one of my Wagoneer's I also noted that the rear quarter window seal was leaking too.
On top of all that the rear doors from the factory really did not seal that well either.
Old 01-19-2020, 06:44 PM
backroadin''s Avatar
backroadin' backroadin' is offline
This... and I also suspect my rear cargo area window seals are leaking too - I've noticed drops of water going down the inner wheel well toward the front, and I know they leak into the way back cargo area. I have some water on the rear floor in the area pictured above after a hard rain.
Old 01-20-2020, 04:53 AM
Brynjminjones's Avatar
With my Wag, the biggest leak by far was from the plastic sheeting inside the doors.
Mine was put on badly so any water that entered the door was directed right over the weatherstripping and onto the floor.
I almost entirely fixed the problem by reapplying the plastic sheeting.
There's a slot in the bottom of each door that the sheet should tuck into. This makes sure that any water running down it goes back into the door and out of the drainage holes.
Also pay attention to where you apply whatever adhesive you use. I used black butyl tape and made sure that it helped to channel the water in the right direction.
1991 Grand Wagoneer - Hunter Green
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 01-21-2020, 09:10 PM
Great thoughts, thanks guys!
water in floorboard arkiejeep General FSJ Discussion 5 02-08-2013 06:14 PM
Moisture and Heat Passenger Floorboard ajminla General FSJ Tech 7 08-12-2011 08:52 PM
Floorboard repair question. (w/pics) Blake General FSJ Tech 12 11-16-2009 08:46 PM
Curious lack of oil puddle CustomWag General FSJ Tech 13 09-19-2006 01:44 PM
Rust patches on GW floorboard onlywoody General FSJ Tech 1 02-22-2004 02:50 AM
