  #41
Old 08-18-2008, 10:59 PM
Keman's Avatar
Keman Keman is offline
So, now I have rebuilt the carb, cleaned up the engine some, replaced a belt, and am still needing to fix the exhaust leak. I started the paint this weekend by sanding and shooting the tan for the roof. (it was too hot outside to do much more than that)
She runs great, even did a death run test in stop and go traffic on I-5 through downtown Seattle in 90+ weather. She ran well, and took the heat without an issue.
Now the Kaiser is finally parked at my house so I can work on it whenever I like, instead of an hour away at my girlfriend's place.
You might worry less about what most people think, if you understood how rarely they do.
67 Kaiser J3000, 327 vigilante, D44/D53, less than average rust. Currently "asthetically challenged"
05 TJ, wheelin rig.
Old 08-19-2008, 07:28 PM
mic63's Avatar
mic63 mic63 is offline
Finished the front axle. New seals and bearings. Took it to a local Threshing show and got into the parade. Their was a long incline that worked out great. In 4WD low and first gear, I was abel to let it idle up hill. With all the other tractors thumpin and being the first vehicle behind the steam traction engines, you could'nt hear in running. A lot of thumbs up and suprised looks on peoples faces after the anouncers let them know it is a 1963. At the auto shows I hear "Nice Jeep". At the threshing shows I hear so many Jeep stories, it's a very fun time. This years best stories came from a guy that worked for Kaiser Jeep during the 1960's as a sales rep for the upper midwest states.
1963 Wagoneer. 230 OHC Tornado. Three on the tree.
http://s146.photobucket.com/albums/r...63%20Wagoneer/
Old 08-19-2008, 08:05 PM
orangecherokee's Avatar
finished putting the roof on my rig.
Old 08-19-2008, 08:18 PM
Justin Kerns's Avatar
Justin Kerns Justin Kerns is offline
Finished my razor grill swap.
Justin
79 Cherokee S 360, TH400, QT
Old 08-19-2008, 08:25 PM
fulszjep's Avatar
fulszjep fulszjep is offline
What I did to jeep
Bought tilt column from ebay. Column from a super or super custom wagon. Picked up winch and ramsey bumper. Got a chrome transfer case shift knob. Got a a/c unit that has the chrome package vents. Got my indicator lights red and green 2 light set up.
1970 Jeep Custom Wagoneer
1967 Super Wagoneer
Old 08-19-2008, 08:27 PM
woody87 woody87 is offline
need help pickin a carb.
ok i am wondering what would put out better performance or mpg a holly truck avenger carb in 470 cfm or 670 cfm?
Old 08-20-2008, 07:27 PM
shimniok's Avatar
shimniok shimniok is offline
Thankfull all I've done to it lately is drive it.
Old 08-24-2008, 02:49 PM
Long&Low's Avatar
Long&Low Long&Low is offline
I mounted the 2000 TJ fuel tank in under the bed of my J10, worked out well. All need to do is plumb the lines and run the electric for the pump.
Breakfast amounts to one live toad, I choke that mofo down, and I am rest assured that nothing worse will happen to me for the rest of the day.
___________________________
CJ truck project
'18 Jeep Renegade
'15 Jeep Cherokee
Old 08-24-2008, 03:16 PM
Chumley360 Chumley360 is offline
I got the G30 trailer hitch modified, welded, painted, and installed. I got the first coat of paint on the fenders and rocker, they'll need to be wet sanded and shot again I've got orange peel. Got most of the front face cleaned up, drilled, and welded before paint. And I've got a back ache.
1968 M715-Driveway queen/in progress
Old 08-24-2008, 03:59 PM
401c.h.i.e.f.'s Avatar
401c.h.i.e.f. 401c.h.i.e.f. is offline
went from stock on 35's
to bad a$$ on 38.5 mickeys on 15 x 14 alcos
Old 08-25-2008, 09:24 AM
painted the roof and began my center console. coming out pretty good so far.
Old 08-25-2008, 09:45 AM
bmoose's Avatar
bmoose bmoose is offline
What I did to my Jeep?
Helped finish up the re-gearing. 3.54 now, from 2.87.
New bearings, seals, slik-um in the rear axle.
Repack all bearings in the front as well as new slik-um up front too.
Really pulls now!
Speedo is lots more accurate.
Now to see what my gas footage will be.
79 LTD Mudbug
TFI ignition upgrade
K&N air, electric fan , FLOWMASTER 50
3" Rough Country lift & 31x10.50's, 3:54 gears
I Rebuilt the QuadraTrac! (now I know how it works)
NO EMISSIONS JUNK !!18 mpg best to date.
Huntin' rig supreme!
Old 08-25-2008, 10:41 AM
Josh D's Avatar
Josh D Josh D is offline
Adjusted the timing
Added power steering fluid
Added a quart of oil
Ran to Home Depot and hauled home a new riding lawnmower
'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
Old 08-25-2008, 12:16 PM
chrisnsarah's Avatar
Cut rotted floor out of the driver's side of '79. Was grinding old floor bondo to get to rust, but ran out of discs.
Cleaned up '67 timing chain parts, set the new set on the crank and cam, and ran out of time.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 08-25-2008, 12:17 PM
cavalryman40's Avatar
cavalryman40 cavalryman40 is offline
Removed the cracked pig nose grill on my 1979 Wag, and installed a new to me $25.00 Razor grill I picked up at a estate sale this weeked.
Old 08-25-2008, 12:21 PM
Knuck's Avatar
Knuck Knuck is offline
Pulled the Radiator so I could take it to the shop to have it flushed and the tanks resoldered. Also began the install of a Rhino grill. Also cleaned up and primed some rust spots.
Oh...I almost forgot. I also installed a new to my Son steering wheel. He is happy now...except for the fact that he can't drive his truck til I get his radiator back from the shop.
Old 08-25-2008, 12:35 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Ran it for a while to keep the battery up, minor tune up this coming weekend.
Looking to do a steering box/pump swap in October.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 08-25-2008, 04:16 PM
VonBoomenstien VonBoomenstien is offline
Boxed the frame from the shock mounts back and added new plates for all the body mount points.
Old 08-25-2008, 04:23 PM
Knuck's Avatar
Looks like we get to fork over some $$ for a new radiator. I was hoping it was just a solder joint on the top tank. Turns out we had some bad tubes as well.
Old 08-25-2008, 05:34 PM
NCOfab's Avatar
NCOfab NCOfab is offline
check my pics on the cherokee i added a hand full more of my body work progress
81 j10 honcho with a stroked amc 360/727/208 tts soa kit, and bjs 4inch lift 35inch baja claws
http://ncofab.ca/ in the works
79 j10 amc 360 t18 d20
79 j20 amc 360 auto np208
81 honcho sportside
NCOFAB Facebook
