Old 12-21-2005, 04:03 AM
89grand's Avatar
89grand 89grand is offline
Resident ***hole
Thumbs down
OK so my choke hasn't worked in quite a while, it's not a huge deal here in AZ but it is cold enough to make my Grand run like crap until it warms up.
Anyway, the plastic part that you adjust for rich or lean and has the wire going to it seems all screwed. I can just move it back an forth and pretty much pull it out if I wanted to, what locks that piece in place so that it doesn't move? I can't see anything around it that you would loosen up to adjust it so how does it stay in place?
Napa has the plastic part with the spring in it, but I don't know if that's what my problem is, because I still don't know what should hold it from moving around.
I admit I'm being lazy and haven't really looked at it all that close, I figured I'd get an answer here instead. [img]smile.gif[/img]
Steve
1989 Black Grand Wagoneer, BJ's 4" lift, ProComp ES3000's
31x10.5x15 BFG AT KO's,MSD 6A,TFI upgrade,360,727,229,2.72 gears.
2006 Dodge Magnum R/T
2000 Jeep Wrangler
1988 Cadillac Brougham
1966 Dodge Monaco 500 383
1965 Pontiac Tempest 326
Old 12-21-2005, 04:22 AM
illegalFSJ illegalFSJ is offline
That round plastic part was originally held on by 3 rivets with tabs around them that held the cover in place. Typically, these rivets get drilled out at some time and replaced by screws, but retaining the tabs that hold down the cover. If you were to purchase a choke assembly for the carb, it should have all the parts you need to gets yours working again.
"Well, what gears do you have? If you have 2.72s in there still, a blown big block with jesus himself working the gas pedal couldnt get the rear tires to slip." -Mavawreck
Old 12-21-2005, 04:37 AM
89grand's Avatar
Resident ***hole
I haven't found an entire choke assembly for sale anywhere, just the round plastic part or the choke pull off assy.
Is the round plastic part really all I need?
Steve
2000 Jeep Wrangler
Old 12-21-2005, 04:42 AM
chrisnsarah's Avatar
There is supposed to be a gasket between the plastic housing and the carb body. The retainer ring also goes on a certain way to keep it tight. If you're carb or choke have been messed with in the past, check these areas. Hopefully, you don't have the rivets.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 12-21-2005, 04:50 AM
If you just get the round plastic part, it *should* come with the spring inside it, 3 screws and 3 hold down tabs.
Old 12-21-2005, 04:53 AM
89grand's Avatar
Resident ***hole
Alright, thanks.
Steve
2000 Jeep Wrangler
Old 12-21-2005, 05:04 AM
89grand's Avatar
Resident ***hole
That sucks! Napa has the part online (pn CRB2158), but of course they don't have it in stock at any Napa near me and the guy said it's a special order part.
Steve
2000 Jeep Wrangler
Old 12-21-2005, 05:15 AM
J10addict J10addict is offline
I got the replacement from NAPA about a year ago for my last 88 J10. It was pricey (and I get the jobber discount) and did not come with the retainer ring or the screws.
69 Ambo coupe, 401, M12
66 Ambo wagon, PS,PB,Tilt,AC,PW Woody
78 GMC Royale motorhome, 03 FLHTCI
01 XJ, 02 Caddy Seville
Old 12-21-2005, 07:45 AM
BigTim BigTim is offline
If you are near Ecology on 27th Ave., they have a GW in the back of the truck section right now. As of Monday, the carburetor was still on it. A whole carb is only like 15 bucks, if you want to buy the whole thing.
Tim D
Old 12-21-2005, 08:49 AM
89grand's Avatar
Resident ***hole
I might have to go check that out. I live in down town Phoenix so it's not too far.
Thanks for the heads up.
Steve
2000 Jeep Wrangler
