Old 12-20-2005, 12:09 PM
creeker's Avatar
creeker creeker is offline
Hey guys, merry Christmas.
Man some snow would be cool. You know for the jmonster.
Any way have any of you guys had to replace your fuel filler lines on your J trucks. I went to by one and no body has one of the preformed variety, so I thought I would get a universal one. Man is this stuff high dollar! I got the wrong size of course, just eyeballed it. It seems that the neck on the cap is smaller than the neck on the fuel tank. Does any one have a fix for this that might stop the trial and error method. Its very cold out and I would like to get it right the first time. ( or second time as the case may be)
If you are happy stay that way...if not get that way...life is to short not to.
Old 12-20-2005, 01:44 PM
UtilityRob's Avatar
UtilityRob UtilityRob is offline
Merry Christmas to you and your family!
I just did this last week. Nothing out there, and couldnt find any NOS. However, i did buy a couple feet each of 1 1/4" and 1" fuel line and it worked. The metal filler neck has two nipples, and the tank also has two, but the factory in their infinite wisdom, designed the tank connections to be wider than the filler neck. Never mind, by using a good quality hose clamp, you can get the hose to tighten on the nipples satisfactorily. While at the hose store, pick up a foot of spring wrap to keep the big hose from kinking as it makes its bend up to the filler neck from the tank.
81 Honcho - original paint, decals. Handmade rollbar to match the original; 2" Rusty's lift; 33" BFG ATs; Cruise; cold R134 A/C; AMC AM/FM/CB; 360, T176, 3:31, new Warn hubs; repainted Stock Wheels (w/ red pinstripe); restored stock interior; AND even with all that junk, a blast to drive every day.
Old 12-20-2005, 02:53 PM
Magnum CJ Magnum CJ is offline
I spose you could bend up some appropriate pipe or tube and just use rubber "couplings" at each end to keep from kinking.
I'm gonna have to do something similiar real soon. mine leak out the gas all over the pavement if you fill the tank up to hose filler height.
A.K.A. Dion F. <br />92 XJ 4.6L HO Stroker <br />79 CJ7 Mopar 360 Magnum V8 MPI/NP435/D300 with 4to1 low <br />85 J20 Pickup AMC 360/auto/44 front/FF60 rear w/1000lbs of rust <br /><br />Insanity has replaced reason in the modification of these vehicles......
Old 12-20-2005, 05:42 PM
illegalFSJ illegalFSJ is offline
The filler neck on older J-trucks is one of those parts made out of "un-obtanium". One way to get around it is to take your old filler neck to a custom exhaust shop and have them bend you a new neck out of metal. Then, you just need 2 short sections of appropriate-diameter fuel hose at either end to secure the tube. I've been able to find this large-diameter fuel hose at some speed shops.
"Well, what gears do you have? If you have 2.72s in there still, a blown big block with jesus himself working the gas pedal couldnt get the rear tires to slip." -Mavawreck
Old 12-23-2005, 04:26 AM
Geeeep's Avatar
Geeeep Geeeep is offline
The large diameter fuel hose is available from Napa (online) I think it's part #1055 2-1/4" fuel filler. It ran $16.89 or something like that I bought some last week. You'll get a 3' length.
Dave Pitts, located directly over the center of the earth!
GW - 87 GW 360/4bbl/727/208 Vinyl floor, manual windows, no woodgrain
Find someone to haul your Jeep here: YT Hauling Schedule
