Old 04-03-2006, 05:53 AM
illegalFSJ illegalFSJ is offline
I'm putting my gas tank back together for re-installation, when I noticed that the steel return line at the top of the fuel sending unit is loose. I'd like to try to fix it before buying a new unit. Is this something I can solder? If so, what kind of flux should I use. I notice that there's acid core, resin core, and others. Any suggestions are appreciated; I have an iron, but just barely know how to use it.
Thanks!
"Well, what gears do you have? If you have 2.72s in there still, a blown big block with jesus himself working the gas pedal couldnt get the rear tires to slip." -Mavawreck
Old 04-03-2006, 06:07 AM
Don S's Avatar
Don S Don S is offline
Gone,But not Forgotten.
Cool
illegalFSJ;
... I resemble that problem!
I cleaned, degreased and sanded the area then J.B.Welded the area. That was well over ten years ago and no problems since.
Have a good one and CUL Don S..
Sold our 1976 Wagoneer 406, MC4300, TH400, QT, TruTrac, 2" lift, 31x10.50s, duel Optimas,
It’s took us over 161 Colorado Mountain Passes, 3 Jeep Jamboree USAs & 2 Ouray Invasions from 1985 to 2010
ACRONYMS & ABBREVIATIONS HERE
Old 04-03-2006, 06:13 AM
Hey, JB Weld sounds even easier than what I had planned!
