Old 03-01-2006, 02:35 PM
RobM's Avatar
RobM RobM is offline
On my 88GW I have a leak somewhere near the oil filler, both the valleys on the left and right of where the upper radiator hose comes in. The valve cover gaskets are new and the oil cap is new.
any ideas?
thanks
Rob
'88 Grand Wagoneer
Old 03-01-2006, 02:45 PM
illegalFSJ illegalFSJ is offline
You can remove the bolts in those "valleys" and smear some sealent on them, then re-install and torque to spec. If the oil re-appears, then you'd know it wasn't coming from the bolts. This has worked for me on several GM 350 engines.
If the oil re-appears, I'd take a good hard look at the valve cover gaskets again. Just because they're new dosen't mean they're in there properly.
"Well, what gears do you have? If you have 2.72s in there still, a blown big block with jesus himself working the gas pedal couldnt get the rear tires to slip." -Mavawreck
Old 03-01-2006, 02:47 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
Front rubber gasket under intake manifold most likely has dried out and cracked letting oil out from under the intake, common problem.
Old 03-01-2006, 02:55 PM
RobM's Avatar
illegalFSJ - do you know what those bolts are called so I can look up their specified torque? Or better yet do you know the torque?
thanks, will look at the manifold gasket too!
'88 Grand Wagoneer
Old 03-01-2006, 03:59 PM
Intake manifold bolts. They torque to around 43 ft. lbs. Smear a little pipe sealer on there to keep the oil from winding it's way up the threads.
[ March 01, 2006, 10:02 PM: Message edited by: illegalFSJ ]
Old 03-02-2006, 02:13 AM
letank's Avatar
letank letank is offline
oil filler pipe could be loose.... can you yank the pipe up... or twist it.....
remove clean both side and put a dab of permatex #2
Michel
Old 03-02-2006, 10:17 AM
chrisnsarah's Avatar
Replace the neophrene gasket at the front of the intake with RTV. It seals better. Also hammer out any indentations from overtightened bolts in the valve covers. Put some loctite on the cover bolts and snug them down lightly.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 03-02-2006, 11:42 AM
baybilly's Avatar
baybilly baybilly is offline
take a good look at the timming cover where the oil pump gear shaft is pressed in. i had a oil leak there and it took me a week to find it. the oil ran down and looked like filter was leaking.
baybilly = dave
77 cherokee S ,parts
84 J10, parts
51 Willys
88 XJ, DD
1966 GT-350 mustang/ project
Old 03-18-2006, 02:23 PM
blakeusa45 blakeusa45 is offline
Have a similar issue- leaking at the filter/adaptor connection. Brand new engine. No oil dripping down from valve covers, intake, timing cover and filter on tight.
New AMC 401 w/ high compression rig putting out 400Hp.
Was told there is a pressure release valve on the side of the oil filter adaptor. Was told I may have a high pressure spring which may be putting too much oil pressure on the filter connection when it opens. Filter is tight, but it's leaking. Other idea is that the connection is not flat...
Any other ideas
Have orderd a new oil filter adaptor and will replace the spring
1971 J4000 AMC401...400hp<br />Old School Rules
