Old 05-31-2020, 05:13 PM
73wag 73wag is offline
Name that part... Please!
Hello All,
I started back on getting my 1973 Wag - "little red mule" back in to shape for
Brakes, undercoating etc. down the rabbit hole i go.
Anyways I am trying to find the correct part or DIY fabrication ideas for my rear seat anchor pillars, when fold back and lock in place.? Not sure what to call them. Any help or Fabrication suggestion would be great.
Couple of shots if the part in question and Jeep.
PS. Any suggestions on replacing the instrument panel dash bulbs?
Thanks in advance! - Matt
Old 05-31-2020, 06:30 PM
Rusty76 Rusty76 is offline
For the dash bulb you should be able to reach up and turn the unit that holds the bulb. Very nice unit. Good luck
1976 Jeep Wagoneer
Rebuilt, 360, TH400, QT.
Still not running. Soon!
Old 06-01-2020, 08:30 AM
chubbinius's Avatar
Like Rusty said, the bulbs in the gauge cluster are just some small twist in sockets that the bulb plugs into. If the sockets are corroded or worn, you can buy new ones from either BJs Offroad (let them know you are a member b on this forum for a discount, if you haven't already) https://www.bjsoffroad.com/Instrumen...ket_p_494.html
or from PartsDude4x4 https://stores.partsdude4x4.net/sock...-cluster-each/
As for the rear seat latch anchors, a Fastenal/Mcmaster Carr/good Hardware store should be able to help you match up a spacer/sleeve/bushing and a shoulder bolt or similar to work. You'll likely have to do a really good weld of a new threaded insert into the wheel well to thread it into as well.
Red mule looks good...even on the jack stands!
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 06-02-2020, 07:17 PM
Thank you very much to you both for your help! Now I know where to start.
On the dash lights, Do you need to pull the screws and pull out the instrument insert out, because I'm not getting much slack to get my hand behind to unscrew the bulbs. Maybe a wire is hung up, seems like a tight fit with the steering column.
Or is it better to try and reach up from underneath, up from the gas peddle?
Old 06-03-2020, 04:33 AM
You will need to reach up underneath and unscrew the speedo cable to get the cluster out far enough to gain access to back of it.
Old 06-03-2020, 06:39 AM
I found it possible to reach in directly behind the cluster. After removing all the screws it is possible to pull the cluster out far enough to slip a hand in. I install the same way.
Resistance is not futile yet.
Old 06-04-2020, 09:03 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
that is a nice red wagoner
something about older red wagoneers like yours looks so good,...
another member on here "driftwood"
has one very similar to yours and it looks great too.
the aged red paint kinda looks even better than a newly painted rig.
good luck with your wagoneer.
dave in NC
need holley fuel bowl part # mltxj9889 General FSJ Tech 15 04-26-2010 07:59 PM
QT Post of the Day: Part Time kit and other questions... shiner2001 General FSJ Tech 18 11-01-2009 03:48 PM
Part number cross over cdlongjr General FSJ Discussion 1 10-24-2009 08:39 AM
1310 - 1350 u-joint part number Blake Off-Road FSJ Tech 13 08-27-2009 09:14 PM
body part removal Mike7009 General FSJ Tech 2 06-09-2004 02:41 PM
