Old 05-31-2020, 03:38 PM
wacker wacker is offline
79' Waggy "John Candy"
Alright, after a few lessons learned on posting, starting a build thread for my new-to-me 1979 Jeep Wagoneer.
Recently drug home a Wagoneer Limited. Running and driving shape, poor cosmetics in and out.
-Mechanical
360 with Edelbrock 4 barrel, turbo 400 and Quadratrac. Working on deleting what emission and vacuum items I can to simplify before tuning the carb. Researching the ignition upgrades, currently has a Malory ignition coil.
Brakes; I'll go through and replace any worn parts. They work but are a little soft currently. Parking brake cable needs replaced.
Steering; just took apart and tightened the tilt column. Next will be replace the rag joint and inspect the TRE's.
Body; Ive got maybe 2 sq ft of floor boards to replace. Most of the damage on the driver's side. Rear quarters and inner fenders are rotten so I will be cropping and replacing as much as possible. I'm motivated to attempt making my own panels. If that turns out poorly I'll order patch panels.
Interior; Gutted it the first week home. So much moisture in the carpet, and the seats are beat. Looking at local Pick-N-Pull for fronts to swap in and will try to get rear bench recovered.
Pics to follow.
-wacker
Old 05-31-2020, 05:25 PM
levelhead's Avatar
levelhead levelhead is offline
You'll want to stop the water coming in....vents, door seals etc. All covered in this forum.
I gotta ask coming from Canada...Why the "John Candy" ?
1988 GW (2)
1980 Cherokee Laredo
1979 Wagoneer
1976 J10 401
1977 Wagoneer 401
1977 J10 4 speed
Old 06-01-2020, 11:55 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
I was hoping the John candy reference
meant it was a Burgundy one
like John drove in the great outdoors.
good FSJ project,.....John was great !
dave in NC
Old 06-02-2020, 07:32 PM
Old 06-03-2020, 10:15 AM
bluehwy's Avatar
bluehwy bluehwy is offline
Fun stuff! Being in CA I may have parts for you. I'm modifying my 79 and won't be using a lot of the original parts. Good luck with your project!
Previous: 1988 Grand Wagoneer
Current: 1979 Wagoneer
"Well I've been down so GD long! and it looks like up to me..." Furry Lewis
I'm Back! Got another Waggy! Randyzzz General FSJ Discussion 26 11-27-2011 09:00 PM
'91 FSJ Waggy Metrohick General FSJ Tech 2 07-19-2010 01:38 PM
Recovered the Waggy Saturday Slick Willie Off-Road FSJ Tech 17 10-06-2009 10:38 AM
Need help troubleshooting electrical (waggy turns over, no start) Blake General FSJ Tech 5 11-14-2007 06:10 AM
my tow truck emt big rich's waggy today Tow God General FSJ Discussion 2 06-11-2007 03:08 PM
