Old 05-20-2020, 06:16 PM
What's the best way to buy front axle U-Bolts?
Should I just order the kit from BJs? Should I look up part numbers from McParts? Amazon? I just need stock size U-bolts, but Grade-8. Any pointers?
79 Cherokee Chief
Old 05-20-2020, 06:21 PM
78 WIDETRAC's Avatar
I have gone to the local spring shop. They were able to bend them up in 15 minutes or so. I did have my old one's they used for the measurements.
Old 05-20-2020, 09:30 PM
I did a quick search in my area and do not see any decently rated spring shops around here. I got lazy and just ordered a set from BJs. They are only $35 shipped for the entire front set. I hope they get here quick!!!
79 Cherokee Chief
front axle load Pullie General FSJ Discussion 2 12-19-2010 07:08 AM
vacuum disconnect front axle haynesm General FSJ Discussion 5 09-20-2010 05:21 PM
How to convert Dana 60 GM front axle to coil springs? Subic Jeep Off-Road FSJ Tech 25 01-14-2010 08:26 AM
D44 front axle bearings - am I missing one? hzl6cm General FSJ Tech 13 08-24-2004 05:42 PM
(TOM) Spring replacement lifts Sitting Bull Suspension and Steering 0 10-02-2001 02:06 PM
