Old 05-06-2020, 09:33 AM
SnowShoe's Avatar
SnowShoe SnowShoe is offline
Exclamation reinstalling tailgate
I'm looking for some tips about reinstalling my tailgate torque springs.
Old 05-06-2020, 10:06 AM
Kaiserjeeps's Avatar
I detailed this in my Another 70 wagoneer build thread. In short, having the gate held upright by two helpers while you are inside to guide the rods and hinges. With the gate upright it removes the tension. The gate was brought forward and just above the hinges to get everything landed. Then ease the gate down on the hinges and tighten the hinges keeping it all in place. Adjust and tighten as needed. I padded and taped and covered all new paint. It went better than I thought it would. It takes three people....
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
71 project J truck FOR SALE
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's
Old 05-06-2020, 09:12 PM
78 WIDETRAC's Avatar
Here is how I did it by myself on the 79. Original gate was missing and the hinges were in still installed in the body. The spare gate was in the back cargo area uninstalled.
*****Big plus for me is that gate was empty.... no window, or lifter assembly.*****
1. Remove hinges completely. Whether they are on the gate or body
2. Installed the tension rods into the bottom of the gate slot.
3. Next I put the rods into their little pocket on the lower hinge.
4. Then loosely bolted the hinges to the gate.
5. Next Because the gate was not full of everything I lifted the gate onto the rear of the jeep and loosely latched it.
6. This allowed me to lean over the gate, line up the bolt holes with a slim screw driver the bottom hinge bolt hole and using the longer bolts.. start them into the body.
7. Get them snug enough to operate the gate for adjustment
8. Then I put all of the stuff that weighs the gate down into the gate.
Old 05-06-2020, 11:03 PM
SJTD SJTD is offline
I did it alone also.
I mounted the hinges in the tailgate, aligned with pins in small holes I drilled before removing them. Supported it on a wheeled cart, installed springs in gate, plugged it into the vehicle, installed bolts to vehicle, closed it most of the way, bolted down the the springs, fine tuned the alignment.
I also had the glass out for this.
Sic friatur crustulum
Old 05-07-2020, 09:15 AM
SnowShoe's Avatar
Lightbulb
I have to install my tailgate by myself also so those last two tips should work for me...I hope.
Tailgate electrical/mechanical repair Driftwood General FSJ Tech 33 02-08-2020 10:09 PM
Finally serehill Homegrown Vendors: (Members who produce FSJ related items) 67 09-06-2017 01:24 PM
Reinstalling tailgate - F... trucking rods! Shep 762 General FSJ Tech 9 05-18-2016 07:22 AM
Repairing the tailgate switch - You can do it too! Jeepster226 General FSJ Tech 8 08-28-2010 11:29 PM
electrical issues tailgate window westcoastflea General FSJ Tech 1 06-21-2006 06:06 PM
