Old 03-19-2020, 05:49 PM
SC/397's Avatar
SC/397 SC/397 is offline
AMC 428 Stroker
Not exactly a full size Jeep engine I guess but it sure sounds cool.
Click on it to hear it idle.
IMG_2883 by Rick Jones, on Flickr
The build is on page 36 under 71. Rotroo390:
https://rebsamcandjeep.proboards.com...builds?page=36
Old 03-19-2020, 06:46 PM
78 WIDETRAC's Avatar
That thing is awesome sounding.
Old 03-23-2020, 03:05 PM
My goodness!! That sounds juicy!!!
79 Cherokee Chief
Old 03-23-2020, 09:28 PM
FleetFox FleetFox is offline
more bigger! More beautiful work from out on the farm. Nice Rick.
Fleet Fox
Old 03-24-2020, 08:26 AM
Full Size Jeeper's Avatar
What kind of horsepower?
1978 Wagoneer
Mods:
Old 03-24-2020, 07:16 PM
SC/397's Avatar
We didn't get to dyno it due to the country shutting down.
We built another engine with the same specs as this one with a slightly smaller cam and it dyno'd at 643HP and 592#/ft of torque.
Page 3, Brad's 427: https://rebsamcandjeep.proboards.com...no-time?page=3
Old 03-25-2020, 05:40 PM
That's a Beast!!!!! You always doing fun sh..t. I guess someone has to do it.
1978 Wagoneer
Mods:
Old 03-25-2020, 06:37 PM
SC/397's Avatar
Yea and it only took 64 years to get to this point.. LOL!
I worked on this cool sh..t today. Replacing the rear end with the correct AMC20. Yea it is the real McCoy, one of two cars that set a whole bunch of records in 1968.
IMG_2920 by Rick Jones, on Flickr
Old 03-25-2020, 07:11 PM
NICE! Are those brackets for some sort of quick jack set up for changing tires?
1978 Wagoneer
Mods:
Old 03-25-2020, 07:23 PM
SC/397's Avatar
I think that they were for wheelie bars. After it set 24 hr speed records, it was modified to do a land speed record, then it was modified for drag racing. I am trying to get it back to the original version somewhat.
https://www.youtube.com/watch?v=QkWgwgt7j30
Old 03-30-2020, 06:34 PM
Im guessing that all the extra displacement is via Stroke? The 401 bore puts it close to the limit already...
Old 03-30-2020, 07:03 PM
SC/397's Avatar
Yep, the bore was 4.208" and the stroke is 3.85". We have the crank off-set ground to 2" journals. We used Compstar 6" rods and Race-Tech pistons made to my specification to get the compression ratio around 13:1 to take advantage of E85 fuel.
Old 03-31-2020, 10:57 AM
DBX11's Avatar
DBX11 DBX11 is offline
how did you get ahold of this car Rick? I read about it just recently and now you post pics of it in your garage... that’s awesome.
Old 03-31-2020, 12:31 PM
SC/397's Avatar
It doesn't belong to me. I am just working on it for bragging rights. LOL! Believe it or not, both cars are within 40 miles of each other right now. I am working on the #1 car which has the 390, and the owner of the #2 car which is a 290, is a friend of mine. I went to look at the #2 car last week end. Living the dream!
Old 03-31-2020, 03:50 PM
DBX11's Avatar
Lucky you, snap a pic of the exhaust if you will and let us know what type of exhaust it has. It sounds great.
Old 03-31-2020, 04:30 PM
SC/397's Avatar
LOL! It has no exhaust, just open headers.
Old 04-12-2020, 01:45 PM
cw05 cw05 is offline
Very cool! Just watched the video. Does the driver's side door not open? Any special mods to the motor to help it sustain long-term high RPM's?
Old 04-13-2020, 08:01 AM
SC/397's Avatar
Yes the driver's door opens but a PITA to climb over the roll bar.
The engine was suppose to be "stock" but they ran a hotter cam, headers, a 8 qt oil pan, and engine oil cooler. So, who knows what else they did. They had oil cooler for the differential as well.
This is kind of a neat picture when you know the story behind it. They had pulled the engine which is why it is sitting so high in front. They were building a Supercharged engine to make the Bonneville run. Oh, and notice the engine oil cooler mounted behind the bumper.. We just bought one off of Epay for $850.00. Ouch!
BreedloveNoEngine by Rick Jones, on Flickr
IMG_2927 by Rick Jones, on Flickr
IMG_2928 by Rick Jones, on Flickr
I have been posting up more detailed information starting on Page 4 over here: https://rebsamcandjeep.proboards.com...rations?page=4
Old 04-13-2020, 06:01 PM
levelhead's Avatar
levelhead levelhead is offline
Yes...very cool video. The sound of that AMX coming off that trailer...beautiful.
Lights out ?...probably running eu Hellas and roasted the switch/harness...should have had Serahill in the pits...thanks for sharing Rick.
1988 GW (2)
1980 Cherokee Laredo
1979 Wagoneer
1976 J10 401
1977 Wagoneer 401
1977 J10 4 speed
Old 04-14-2020, 06:02 AM
SC/397's Avatar
The Motorola Alternator failed causing the lights to go out.
AMC 304 V8 Stroker Build - 327 V8 ! Greg Taylor General FSJ Tech 5 02-14-2008 06:55 AM
Ideal stroker block jeeprunner81 General FSJ Tech 11 04-16-2007 05:19 PM
4.0 head swap or stroker? What to do.... J10Joe General FSJ Tech 37 01-11-2007 12:18 PM
4.0 stroker thoughts.... backroadin' General FSJ Tech 3 08-20-2006 08:08 AM
More stroker build questions (getting closer) IslanderOffRoad General FSJ Tech 20 05-14-2006 08:23 PM
