  #101
Old 05-10-2020, 02:41 PM
78 WIDETRAC's Avatar
I haven't been doing much other than cleaning and painting parts.
I have a bj's timing cover I was going to use, but it seems that the stock one is a better choice.
I hope to get it and the water pump installed later, If all goes well the intake also.
I was able to get the 35's mounted on the Centerlines.
Old 05-31-2020, 07:38 AM
Not much to report. I pulled the oil pan so I could check out the bottom end.
I found a new oil pump gear set in my extra parts,
I just need to get an oil pan gasket on order so I can get it back together.
I spent a good portion of the last few weeks cleaning up the 79 chief and putting things back together.
I reinstalled the radiator and few other bits to get it running using the factory gas tank, I also removed the extra rear gas tank from the spare tire area. Next I started getting the exhaust pipes sealed up to the bottom of the manifolds and mounted the factory pipe back up to the t/case so everything will tuck up where it's suppose to go. I will put on a new cat and new muffler because they were busted and blown out.
My neighbors like a normal sounding jeep when they are as close as we are.
I really need to start a different thread on the 79. Maybe after it's a little closer to being a driver.
[url=https://ibb.co/vD012V8][/url]
Old 06-01-2020, 08:40 AM
chubbinius's Avatar
All good progress, and the neighbors will appreciate it, I'm sure!
Need to replace the passenger exhaust manifold on mine (one of the ears to the exhaust/collector has cracked). My neighbor's wife said she "was wondering who had a motorcycle in the courtyard" and when she "went out to the driveway she realized it was my wagoneer warming up".
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 06-07-2020, 07:58 PM
I finally got the last parts I've been waiting on. I hope to begin reassembly this week after work, provided we have good dry weather. I'd like to fire it up this weekend.
Old 06-09-2020, 07:22 PM
WOOOoooo hooooo!!! Love updates on this thread!!!
If you start a thread for your 79, post a link here, too.
79 Cherokee Chief
Old 07-05-2020, 09:13 PM
Still chipping away at it. I installed a different Alt mounting system. I wanted to simplify it. I'm not going to run A/C so I don't need all of the brackets, spacers etc...
I removed all of the greasy power steering stuff so I could clean it all up. Both hoses were cracked from age. They will get replaced.
I power washed a lot of the grease off of the underside today also.
I was able to move the wheel back to center into the wheel well.
I added some cheap 35's on 18" wheels and polished the paint some.
I still have about 50 items to do and or finish before I can drive it.
I'm also working on the 79 Chief too. So it takes my attention from the 81.
Old 07-06-2020, 07:33 AM
dang, looks great.
tuff looking Cherokee !
Old 07-06-2020, 09:45 AM
no kidding! That paint came screaming back!!!
79 Cherokee Chief
Old 07-06-2020, 09:55 AM
Wagoneer Taylor's Avatar
Wagoneer Taylor Wagoneer Taylor is online now
Finally got caught up on this thread!
You've made some serious progress makes me so jealous! Then I see you got another Cherokee! So Jealous of that too!
Doing some awesome stuff here, your dash is looking amazing and engine work is great!
Keep at it.
Some call me Taylor...
Soon to be a 401!
Old Yesterday, 11:01 PM
It will look pretty good when it's all washed and has a proper buff job.
Old Yesterday, 11:07 PM
Keep at it.
Thanks! I was hoping to have it running by now, but working on Two fuel systems that have sat for years takes time. I didn't want to remove the tank until it was higher off of the ground.
I'm re-sanding the dash, and something was living behind the gauges so they need some attention!
The 79 was just around the corner from home depot on Spicer rd in albany.
Old Yesterday, 11:08 PM
Originally Posted by SOLSAKS
dang, looks great.
Thank you Dave!
Azusa off-road videos, pics, and Cherokee review PlasticBoob General FSJ Discussion 12 10-23-2007 05:48 PM
1979 TH400 to 1981 NP208 in 1981 Cherokee 81_BigChief Off-Road FSJ Tech 8 02-19-2006 01:27 AM
1981 Cherokee Chief (Canadian) - Levi Dome Cherokees 0 08-21-2005 12:37 PM
1981 Cherokee Laredo - Tom Anhalt Dome Cherokees 0 08-21-2005 12:36 PM
1981 CHEROKEE FOR SALE - $1800 barillms General FSJ Tech 1 10-02-2002 08:27 AM
