Fuel lines for TBI
  • rang-a-stang
    • Oct 31, 2016
    • 5505
    Fuel lines for TBI
    I am going to plumb my TBI fuel lines this week. I am using my original supply line as my return line. I have a bunch of 1/2" aluminum Moroso fuel line I can use for the supply side but think it may be a bit big? Does that matter? Should I just order some 5/16's or or other for my supply line?
    Also, I have the good ol' fashioned stock 79 tank. I plan to run an inline pump so if it fails, I don't have to drop my tank to replace it. On the pickup, I planned to basically mirror the original pickup (seen below) but with a sock at the end. I plan to have the return line return the fuel over the pickup (basically remove the soft end on the current pickup you see in the picture.
    Thoughts?
    Chuck McTruck 71 J4000
    (Chuck McTruck Build Thread)
    00 Baby Cherokee
  • rang-a-stang
    • Oct 31, 2016
    • 5505
    Anyone use 1/2 line?
    00 Baby Cherokee
    • babywag
      • Jun 08, 2005
      • 10286
      1/2" too big imho...3/8" isn't even required.
      If I was to do one again, I'd probably use the nylon stuff and the required efi fittings.
      I've had several issues w/ metal efi clamps seems the chinese can't even get those right.
      The nylon stuff would allow eliminating clamps.
      I might even switch still? A roll is only like $20 and the fittings are cheap too.
      • rang-a-stang
        • Oct 31, 2016
        • 5505
        I hadn't even considered nylon. Hmm. Thanks.
        00 Baby Cherokee
        • Tripwire
          • Jul 30, 2000
          • 4656
          I reused the carb lines already existing with no issues
          Abort? Retry? Ignore? >
