Old 06-27-2003, 04:12 AM
xj2fsj xj2fsj is offline
A few questions here so I will go by topic
topic #1 "is this the correct tranny?"
Q. how can I tell, for sure, if a tranny that is out of the vehicle, with no info on it's original carrier, is a match for my 1982 wag 360/727/219?
Topic #2 " what signs of wear should I look for?"
Q. is there at least a reliable way to check a disembodied tranny for "bad" signs of wear? I imagine that it has no fluid since it was pulled by a junkyard and is now on a shelf.
Topic #3 "What preperations should I do before I install this tranny?"
Q. aside from a fluid/filter change what else?
Topic #4 "which one? $250 w/ 90 day war. or $200 w/30 day?
Q. I imagine that the extra warranty is a good buffer for a bad tranny but is 90 days enough?
This is kinda a time crunch thing so the most important thing is whether or not this tranny will fit my wag. I appreciate ANY insight, thanks in adavnce. I can't wait to get Ruby back on the road again. She has too much diginity to simply be moved to avoid the tow man!!
A blonde walks into a bar with a poodle under one arm and a salami under the other...<br /><br />1979 Jeep Wagoneer AKA \"Odin\" 360/400/BW1339/fr44-rr44
Old 06-28-2003, 02:08 AM
Sycho15 Sycho15 is offline
TF727 was used from '80-91 so yes it will fit.
Don't know about the warranty, but I'd suspect severe problems would show up within the first 2 weeks. The 727s a good, strong tranny, and they are supposed to be cheap/easy to rebuild. So if you're not turning your old one in as a core you might want to look into rebuilding it yourself for a spare, or to sell to make your money back.
1989 J5 "Murphy"
4.0L / AX15 / NP231 / GW D44s
3" lift / 31" MTs
Old 06-28-2003, 08:23 AM
John V John V is offline
If the tranny was in an AMC V-8 4X4 configuration it will fit. That said I'd rebuilt it, imho the 727 is the one to learn on. A book and a kit should come in much cheaper and you will have a new and valuable skill!
78 Wag 4.3-Th400-S18, 4\" springs<br /> <br />53 Wagon, Mopar 440, 727, Divorced 205, Dana 60\'s <br />The parts are able but the body is weak!
