Old 08-24-2018, 04:26 AM
monte monte is offline
Australian 1983 J20 Vin
Hi, researching details on a j20 I am looking at purchasing, can anyone assist with the Vin number decode?
Vin number 6JBN227YXBD0011233
Some of the code deciphers, but the "B" doesn't make any sense
Jeep presently is a 360 Auto on the floor Town-side Body, supposedly from the factory.
Also what would be the diff options available for this year.
Towing weight capabilities.
Old 08-28-2018, 08:18 AM
mud89's Avatar
mud89 mud89 is offline
VIN decoding :
6 Australia
J Jeep
B should be a type like "truck" (i don't have the exact meaning)
N 360
B Auto floor (i think it's actually "B" instead of "2")
27 J20
Y 8400 lbs GVW
X don't know
B 1981
D australian plant
I guess that the serial number is rather : 1233 ?
Old 08-28-2018, 12:18 PM
I'm not familiar with the OZ VIN codes but the US system would make the 10th digit "B" a 1981 model year not 83.
The 5th digit if "B" not a "2" would make it auto trans w/full time transfercase In 81 that would be the NP 219 which is easy to tell. There is no 2WD mode. If it's really an 83 it would be the NP229 also easy to tell. There would be a two handed 2WD/4WD vacuum switch on the dash. Also the front axle will have a vacuum axle disconnect motor sticking out of the cover. I also don't get your auto trans shifter is on the floor? That was never an option in the US. Sounds like an owner installed modification but don't know about OZ?
The differentials should be HD D44 front, Full floater D60 rear. Standard gearing would be 3.73 but there were optional lower (higher numerically)gear sets as options like 4.10 etc. There should be a ratio tag between two of the diff cover bolts.
For towing capacity? It depends on the class of hitch you have?
Old 08-30-2018, 12:58 AM
mud89's Avatar
Joe, i am not 100% sure since the pic is small , but my understanding is that this shifter is specific to FSJs built in Australia in the eighties, i already saw them several times
There are generally at least one year between the year in the VIN and the sale date, makes me think that maybe the year in the VIN corresponded to the CKD kits
Old 08-30-2018, 01:24 PM
Hi Mud, I'm not familiar with OZ built rigs at all so if you've seen OZ factory floor shift AT's I defer to you. Pretty truck but yeah...tiny pictures.
Jeep J20 apache j20apacheh General FSJ Discussion 23 10-12-2016 09:06 PM
Towing a J20 on a Uhaul trailer jpcoutts General FSJ Discussion 9 08-08-2013 07:07 PM
BIG plans for the J20... **CrewCab** Dmntxn77 General FSJ Discussion 26 06-23-2008 11:58 AM
J20 axles in a J10 - Driveshaft ? HOOT General FSJ Tech 5 06-19-2008 08:36 PM
Factory J20 5/4 ton??? Elliott General FSJ Tech 17 09-20-2004 01:55 PM
