Old 03-28-2018, 03:43 PM
BillyBob535 BillyBob535 is offline
NV4500 with NP208 - clocking
I am going to use my Dodge gas NV4500 (23 spline output) with my Jeep NP208. I have read some places that they fit together with no issues. Some places say I need a spacer. Some say it won't be clocked correctly.
Can any of you who have actual first hand knowledge of the NV4500/NP208 combo clarify which is correct?
It will be ending up in a 76-83 wagoneer or 4 door cherokee running a drivers side drop D44 and 2" of lift (if that matters)
Thanks
Old 04-02-2018, 04:38 PM
Heimeken's Avatar
Heimeken Heimeken is offline
I have that exact same setup... no issues with clocking or spacing. Fit right in.
401, NV4500, 3/4 ton gear
'79 Cherokee "The Sandgorgon"
One Tons, SOA,T18 on 40's
78 J10 "Imoteb"
J20 running gear and axles
Old 04-02-2018, 05:26 PM
That is good to know. I was considering spending the $450 to SYE the NP241DLD that is currently behind the NV4500. Using the NP208 and selling the 241 will save me some money.
Are you running a hydraulic clutch or mechanical?
Old 04-03-2018, 09:20 AM
Heimeken's Avatar
I am running the stock mechanical clutch setup...
78 J10 "Imoteb"
Need NV4500 / NP208 compatability help Tigger4X Diesel Swaps 51 01-30-2012 09:23 PM
NV4500 to NP205, NP208, D300, or ??? Tigger4X General FSJ Tech 3 10-18-2010 05:31 PM
Will Dana 300 clocking ring work on a NP208?? learfxr Off-Road FSJ Tech 4 08-03-2008 05:23 PM
NV4500 To NP208 Adapter leftturn109 Off-Road FSJ Tech 10 06-13-2006 06:04 PM
Clocking a NP208 RamJetFSJ Off-Road FSJ Tech 1 05-19-2006 04:29 PM
