Old 07-31-2014, 07:07 AM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
Transmission linkage bushing. Found a cheap replacement at Lowes!
Since I've owned my jeep I've had problems with loose shift linkage. The shift indicator was more a less a suggestion. So I crawled under today and found some pretty sorry busted up bushings on each end of the bell crank shaft. I had heard you could get these in the Help section at the big parts stores, but I didn't have any luck. So I went to Lowes. In the hardware section they had a selection of nylon bushings. I chose the ones pictured. I had to grind down the outside about 1/16", then tap them into the bracket/keeper with a hammer. The inside diameter is perfect. It went back together perfectly, and works great. No slack at all. Shifts easy and clean. It just took a couple hours including parts runs and test fitting. Total cost $1.58 + tax and gas. Its the easiest, most instantly gratifying thing I've done to the Jeep so far. I hope this can help someone who is having the same problem.
You can see the broken bushing and how loose the shaft is in the bracket.
Here are the old bushings. They are about 1/8" thicker than the replacements, but the replacements are solid nylon. I think they will hold up.
URL=http://s1240.photobucket.com/user/mdcptman/media/Jeep%20Stuff/20140730_210323_zpsl1sdqdor.jpg.html][/url]
Here is the part number and specs. They came 2 in a pack for $1.58!! No ordering and waiting, no shipping. Just awesomeness.
Here is one in the bracket/keeper. I had to tap it pretty hard with a hammer to get it to go in. It fits snugly and has no play. Looks factory.
Here they both are assembled in their brackets and ready to go in.
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Old 07-31-2014, 07:52 AM
8man's Avatar
8man 8man is offline
Good job Todd! Good to know.
Old 07-31-2014, 11:52 AM
Full Size Jeeper's Avatar
Looks good and great info to have.
Old 07-31-2014, 12:00 PM
goldhammer's Avatar
Put a little grease on the rods and they will hold up a little better, and won't wear as fast.
Art
ASE Master Collision Tech
Old 07-31-2014, 02:16 PM
Strode's Avatar
Strode Strode is offline
1st Chair, Cowbell
Brilliant. This should be in the archive section.
Edit: Congratulations, you made the Tech Archives.
Ristow's Bunker
Old 07-31-2014, 02:53 PM
mdcptman's Avatar
Jeep Therapist
Oh my, I think I'm blushing...This is an honor I'll remember for as long as I can....
88 Grand Wagoneer
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Old 07-31-2014, 03:02 PM
Strode's Avatar
1st Chair, Cowbell
It really is a big deal.
You might want to change your signature to reflect the fact that you're a ARCHIVE CONTRIBUTOR. Big Rep stuff there.
Ristow's Bunker
Old 07-31-2014, 04:00 PM
mdcptman's Avatar
Jeep Therapist
Im not worthy! (Cue Bill and Ted)
I just got lucky in finding just the right bushing.
88 Grand Wagoneer
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Old 07-31-2014, 04:08 PM
Driftwood's Avatar
Certainly not Priss worthy
Old 07-31-2014, 04:30 PM
goldhammer's Avatar
Maybe not prissy, but a good working man's solution. (Pats him on back and hands him a cold one.)
Art
Old 07-31-2014, 04:31 PM
mdcptman's Avatar
Jeep Therapist
So true. To do that I would have had to sandblast the parts, run them through an autoclave, then have them gold plated. On my jeep, that would have looked like pearls on a pig. Besides, my gold plating machine is on the fritz.
88 Grand Wagoneer
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Old 08-16-2014, 11:11 AM
Heimeken's Avatar
Heimeken Heimeken is offline
Excellent! my favorite type of fix. Creative and inexpensive
401, NV4500, 3/4 ton gear
'79 Cherokee "The Sandgorgon"
One Tons, SOA,T18 on 40's
78 J10 "Imoteb"
J20 running gear and axles
Old 08-17-2014, 11:28 AM
SlowGear's Avatar
SlowGear SlowGear is offline
Same problem with my 88 - heading off to Lowes now. Great post!
Mike
88 Grand Wagoneer
Bone stock - except the missing stuff
found a cool replacement part for my waggy scorpio_vette General FSJ Tech 10 06-07-2013 01:00 PM
Jeep sat for 2 years, now has tranny problem jpekarek General FSJ Tech 15 02-15-2011 04:20 PM
Cheap, easy replacement springs for post mount J-Trucks KaiserMan General FSJ Tech 9 02-22-2008 11:29 PM
Woot finally found a J10 for cheap xxcoolrollinxx General FSJ Tech 2 06-27-2007 03:39 PM
