Old 07-29-2012, 08:47 AM
Phoebe Too - new carpet
Folks that came to Ouray last week for the FSJ Invasion had a chance to see the new and improved Phoebe Too. We brought her home from Tucson on Memorial Day Weekend with the new body looking groovy but still had to put carpet down. We ordered the ACC kit with mass backing from BJs Offroad right after that. We also bought 19 feet of water heater blanket, rust converter and rust inhibitor paint. We started by removing the seats, rear side panels and cleaning the floor up. Then I went around with concrete silicone crack sealer and sealed up all the body panels where the factory use seam filler first removing any loose pieces. Krista got busy laying down water heater blanket and with carpet fitment. The mass backing is a rubberized coating for the bottom side. It is a bit of a challenge to get to fit & trim some of the tight spots but the sound deadening affect is great. The carpet also came with 3 pieces of 1/2" felt padding cut to fit the cargo, rear and front seat floors. We only used the felt in the front floor for heat and sound insulation. The rubber pad for the cargo area was still good so it went down over the water heater blanket. We don't have a back seat in P2 yet and the rear seat belts and seat latches are not installed. The original tailgate carpet is still holding up OK after 35 years so we have not changed that yet.
Got a few pictures...
Carpet laid in sun to help it relax.
4'X19' of water heater blanket - Krista used 18' and installed it with 3M upholstery and headliner spray contact cement.
The cargo area clean and sealed.
Bob (rstep) had patched a small hole in the RF floor during the body swap and I had some surface rust clean up to do there. After wire brushing and wiping it down, rust converter was applied then 2 coats of flat white rust inhibitor paint. The driver side was much cleaner to start with.
The floor is in great shape for a 34 year old Wagoneer body.
Kudos to Krista for all the detail work.
The wheel wells were tedious work for fitment.
The end result was pretty decent. The door seals are new from Tijuana Mexico and attached with 3M weatherstrip adhesive.
Old 07-29-2012, 08:57 AM
Looks great!
Old 07-29-2012, 09:19 AM
ERobertBurk ERobertBurk is offline
Look amazing! Beautiful work.
Old 07-29-2012, 09:39 AM
ScottsMojo's Avatar
ScottsMojo ScottsMojo is offline
Looks Awesome!
Great job indeed. Krista, could you do me a favor and measure the distance from the lower edge of the brake pedal to the floorpan (in the direction of pedal travel)?
Locked and Loaded's Avatar
Locked and Loaded Locked and Loaded is offline
I like it. Now all you need is some inside tiedown points.
Drink more water.
"Nothin' ain't worth nothin'.
But it's free"
Kris Kristofferson 1970
1981 J10, 258, T176, NP208
Old 07-29-2012, 09:47 AM
HaHaHa! Good point considering what happened. We are not finished. We are never "finished". I will be looking at cargo area SS strip options. All the cargo deck strips we have are beat up and not worthy.
The rollover bent the crap out of the originals where the floor buckled.
When we have a solution for the cargo strips we will also install tie downs and the spare tire carrier. For now the trail runs she goes on will have minimal cargo.
Old 07-29-2012, 09:53 AM
serehill serehill is offline
Gone,Never Forgotten.
That 's awesome.
The insulation was form fit well. That must have taken a lot of work.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 07-29-2012, 09:58 AM
81cherokee laredo's Avatar
81cherokee laredo 81cherokee laredo is offline
Looks real good, I think I'm going to steal the water heater blanket idea
Dan
81 Cherokee Laredo- 360 727 NP219 SOA/SF 35 Coopers 4.56 Gears
83 Cherokee - Katy- long term project
89 Grand Wagoneer- 360 727 NP229 31x10.50's on slot rims
Old 07-29-2012, 10:32 AM
Very nice I m sorry I didn't get to see it in person
Old 07-29-2012, 10:36 AM
will e's Avatar
will e will e is offline
Always Broke
Excellent job! Sure beats the duraliner and diamond plate the previous owner put in mine. It's nice because it cleans out easy but it is anything but quiet. I really have to turn up the stereo to cut out the road noise...
P2 looks beautiful!
Old 07-29-2012, 10:38 AM
svining's Avatar
svining svining is offline
I like it..........
I was expecting "Fuchsia" though! You can find tiedowns on Ebay pretty cheap. Mine came out of a Subaru just cut a square in the carpet (Careful..only one chance). Then a #12 stainless screw through the floor, add some bungee's and voila!
How's the sound deadening (Road noise) effect!
Flashlight
"I started with nothing, I still got most of it left"
1982 GW,Stock, No Emissions Equip.
Mallory HEI, AMC 360, Motorcraft 2150
Old 07-29-2012, 11:21 AM
Jeepstress's Avatar
Jeepstress Jeepstress is offline
The insulation was actually the easiest and most stress free part of the interior! The aluminum bubble wrap is incredibly flexible and forms around curves and into depressions with ease! It cuts well and leaves nice clean edges. I wasn't sure we bought enough insulation so I kept all my scrap pieces and then just "patched" them together with duct tape to make larger pieces that could be cut to fit. The wheel well pic with me shows that in the side piece I'm fitting. The tranny hump took some thinking because there are so many hills and valleys and wide arced expanses to cover but it really was simple. I cut two large squares (the roll was 4 feet wide which was a good width but the foil does come in 5 and 6 foot rolls too). I lined the insulation up with the edge of the floor from the outside and glued flat in towards the tranny hump. Once I got to the tranny hump and started up the curves I trimmed and darted as necessary to get everything to lay down flat. Once that was done on both sides I took all the scraps and cut pieces to fit on top of the hump where I had open space. You can see all the duct tape patches in front picture.
Krista - High Priestess of Our Lady of Eternal Combustion
77 401 Wag "Phoebe" ~ 77 401 J20 "Artemis" ~ 76 401 SOA Wag "Luna"
The worst thing about rolling my jeep.....is trying to lick the paper...
Old 07-29-2012, 11:38 AM
thanks
It really looked good & will improve sound & heating & a/c function.
That rig is really nice. The reincarnation is impressive but we wouldn't expect less from you guys.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 07-29-2012, 12:52 PM
Jeepstress's Avatar
Thanks, but we really played a small part in the Phoebe resurrection. The real kudos need to go to the guys in Tucson that did the lion's share of the work.
Old 07-29-2012, 01:42 PM
looks nice. a clean interior makes for a nice driver.
Old 07-29-2012, 01:49 PM
Jeepstress's Avatar
Well, I wasn't so nice while trying to get the carpet in but I am much nicer now that its done.
Old 07-29-2012, 02:11 PM
Nicely done. Looks great.
Old 07-29-2012, 02:29 PM
yah....i have the patience of a rattlesnake during these projects too.
hey...i get to dig into my wire harness and find why my alt won't charge,neutral switch and start circuits quit working. wanna help? guaranteed to be as fun as painting a fence.
Old 07-29-2012, 02:40 PM
Jeepstress's Avatar
Appreciate the offer Hon, but I stay far far away from electrical stuff. That is just nasty evil voodoo stuff that I just can't wrap my head around. Especially once someone has started butchering the harness!
Old 07-29-2012, 08:50 PM
HD_JEEP's Avatar
HD_JEEP HD_JEEP is offline
Thumbs up That's great work
Just wanted say thanks for sharing it looks great.
DeWooded
6 inch Hellcreek lift.
Rhino Grill
Holley 600cfm
FSJ Full Carpet Kit -Reviews Please?- temps425 General FSJ Discussion 31 10-23-2015 08:45 AM
Wagoneer Rear Cargo Deck Write-up Dr. Marneaus General FSJ Tech 18 07-09-2015 06:50 AM
Power Wash the carpet? Huntindad General FSJ Discussion 3 03-11-2012 03:04 PM
Carpet install help -- flag QT shifter rmorit01 General FSJ Tech 7 12-03-2010 07:16 PM
vinal floor or carpet noise and moisture questions dusty General FSJ Discussion 4 02-20-2009 04:06 PM
