  #41
Old 06-05-2022, 06:42 PM
devildog80's Avatar
devildog80 devildog80 is offline
We did pull the MSD off, and all back to OEM with new ICM and new coil.
We checked, and have, full voltage to and out of ICM, over to passenger fender. Just do not get circuit complete through coil, with voltage to + side.
Checked coil ground...have good ground.....
WHY WHY WHY......... :/
'81 CJ5 Base, 258 I6, MC2100, T176 4 spd, 300 TC, D30 Front NT, 3.31, 2-Piece AMC 20 rear NT, 3.31, 4" high arc spring lift
'84 Grand Wagoneer, 401 V8 (.030 over), MC2150 HA Comp, 727 auto, Selec-trac NP229, AMC 20 REAR - D44 FRONT - WT 3.31, 4" high arc spring lift
Rather be driving, than waiting to be modified
Old 06-05-2022, 09:48 PM
If you pull the pickup connector, there are 2 wires. If you connect a multimeter across those two wires and crank the motor over, you should see slight voltage spikes as the rotor turns past the pickup. Its only a tiny bit though so you have to set your multimeter to (I think) millivolts.
That stock dizzy is a Ford Duraspark. If you look up "Duraspark pickup test" there are a few other tests you can run, too. I replaced mine a while ago and it was pretty cheap (i want to say less than $20?).
00 Baby Cherokee
Old 06-06-2022, 09:49 AM
devildog80's Avatar
Thanks, and going to test it.
For that much, not a bad investment in prevention
Mongo228 has an ICM wiring harness coming too, as that would eliminate the factory nightmare of random splices we found, to make sure we are dead on with connections.
Fingers crossed.....
Old 06-09-2022, 01:05 PM
devildog80's Avatar
Have some of the parts that came with the truck listed in classifieds.
Old 06-18-2022, 12:43 PM
devildog80's Avatar
Well........
Mongo228 and I replaced OEM - PO wiring for ICM with Painless Harness.....still no spark.
Diving into the distributor pick up coil, as this is the last thing not changed, but does test good?
Constant ohm's at 692 across outside terminals at the plug, but investigating further.
Old 06-18-2022, 09:55 PM
cu4whln's Avatar
cu4whln cu4whln is offline
Dang..
I hate electrical bugs.. sooo frustrating !
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver - 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Old 06-19-2022, 12:01 PM
devildog80's Avatar
Mongo228 said to me part ways into the rewire yesterday....."If this does not work, we are dragging it out into the desert, and light it on fire" :/
Tried to encourage him to NOT do that.
Guess it is what you get, with these old trucks
It WILL live again!
Old 06-19-2022, 12:05 PM
devildog80's Avatar
Suspect the distributor might be our weak link now, after wiring and power feed has all been verified.
Just absolutely no spark through coil.
Old 06-19-2022, 03:45 PM
78 WIDETRAC's Avatar
I know you probably looked at this thoroughly, I only noticed the hard brittle cracked wires on my original distributor when I removed it. Cracked 1/2 way between the distributor body and plug, right where the wires rest on the manifold. I honestly would have never noticed them had I not removed the distributor.
Old 06-19-2022, 05:14 PM
devildog80's Avatar
That is a possible fault point, so we replaced the OEM wiring with new ICM harness, and looking at distributor pickup sensor now.
At least I know there is new wiring on the male plug side, and hope we find our trouble with the pickup wiring, but not too hopeful.
The pickup tests ohms, off the connector blades within limits, so yes pulling the distributor is probably our next step.
Thanks for the idea
Need all we can get!
Old 06-22-2022, 01:21 PM
devildog80's Avatar
Also thinking of doing distributor recurve, while on the bench trouble shooting.
Old 06-22-2022, 02:43 PM
You shouldn't need a whole new dizzy. The pickup is cheap and easy to replace. I think I bought an MSD one, and it was like $40... took maybe 15 minutes to install?
00 Baby Cherokee
Old 06-22-2022, 02:48 PM
devildog80's Avatar
Correct no new dizzy needed, recurve you can use a factory distributor, as it is primarily just changing one or both of the springs down in the bottom.
Brings your power curve in at lower rpm.
That is what I took from the youtube vids I watched, with this one being most informative.
https://www.youtube.com/watch?v=7jFlXBCtNCM
Old 06-22-2022, 03:57 PM
sierrablue's Avatar
sierrablue sierrablue is offline
Probably a dumb question here, but how do the other components of the ignition system look? You said you've been through all of the 12V stuff--but what kind of shape are the cap, rotor, plug wires, and plugs in? Is it possible that the plugs got gapped too far? Obviously you're working on making the distrubutor basically brand new, but just other things to double check if it still won't fire.
Current Rig:
'71 Wagoneer (DD)
B350/TH400/D20
open knuckle D44 front (disc brakes)
6-lug conversion rear
http://www.ifsja.org/forums/vb/showt...79#post1734879
Previous Rig:
Tan '88 Grand Wagoneer
.030 over 401, TBI, headers
3" exhaust
31x10.5s
2" rear lift blocks
custom headliner
http://www.ifsja.org/forums/vb/showt...77#post1734777
"The engineering side of me says that it's more than strong enough. The redneck side of me says that it's going to fall apart and I need to beef it up."--somebody I know
Old 06-22-2022, 04:13 PM
devildog80's Avatar
Everything pre distributor has been checked, and now replaced new, and still no spark to the coil.
Not even looking at plugs yet, until I can get spark to pop from coil to distributor.
Distributor/cap/wires are clean and in good shape, but pulling it to be sure gear is ok, then check pickup to make sure it is good.
At same time, will change one of the springs in the bottom for recurve, then when we get it to fire, will regap all the plugs from MSD setting, now back to new ICM settings.
Even at MSD gap settings on plugs, we should be able to have spark from coil, which is our issue.
Replaced battery, start switch under dash, ICM, new ICM harness, coil.
Verified and checked on my CJ5 the new coil, existing coil wire, spark checking tool, that these all worked. Put them back on Wagoneer and no spark.
That leads me to distributor being the only thing we can see, that would cause a no spark issue. Ohms checks ok on distributor pickup, but forgot to rotate it when meter connected.
Thanks for the thought, and still open to any/all info to try and get this issue resolved
Old 06-28-2022, 07:10 PM
Still nothing for spark? I'm surprised. If you want to try a different distributer all together I'd be willing to send you a known good one out of an 86 I parted out. FREE!
Old 06-28-2022, 07:18 PM
devildog80's Avatar
Correct....still no spark, and still need to trouble shoot the distributor, but will not decline an offer like that.
I will PM you
Thanks a bunch
Old 06-28-2022, 07:32 PM
Something in my head that's just lingering is the wiring by the oil sender.
I can't recall if it's a safety thing so I can't fire with no oil pressure. Look into that too.
Somebody will know what its called and the exact purpose I'm sure. I'll crawl under my jeep and post a pic of what and where I'm talking about.
Old 06-28-2022, 07:35 PM
devildog80's Avatar
I do know what you are talking about, as I have that on my '81 CJ5 too.
Definitely check that, as never crossed my mind.
Old 07-04-2022, 10:55 AM
devildog80's Avatar
No progress......too gosh darn hot right now!
More to come......
Good Video on Drum Brakes Herezja General FSJ Tech 10 02-11-2017 02:18 AM
Dormant A/C revival Q's jpcoutts General FSJ Tech 5 04-02-2012 08:28 PM
AMC 20hd axle bearings (revival) Sarge's 7 General FSJ Tech 6 11-01-2004 06:26 AM
