Old 08-19-2019, 10:35 PM
When should my CS144 Charge light come on?
I have an incandescent bulb wired to my CS144 but it never comes on. I have 12.6 volts on the ignition side of the light with the key on but engine not running, 11.something volts on the other side of the lamp going to the Alt. I checked continuity across the bulb and it's good. I have 11.something volts at Pin L at my connector with the key on. I have 14.3 volts across my battery with the engine/electri Fan running.
I'm not so worried about the light, just want to make sure I do not fry my alt... Am I doing this right?
79 Cherokee Chief
Where does the charge light wire hook to in the alternator? 1cdccop General FSJ Tech 3 12-21-2010 05:58 PM
Back-Up Light Assembly Michael Abild General FSJ Tech 2 07-28-2010 10:48 AM
Courtesy light and dome light TestTeam General FSJ Tech 10 06-01-2007 11:20 PM
Map Dome Light -- Wiring as a rear light in Cherokee? rmorit01 General FSJ Tech 4 07-22-2005 09:14 AM
One brake light works...... (update) Georgia Mike General FSJ Tech 8 03-31-2003 04:49 PM
