Old 08-17-2019, 08:57 AM
RVAWagon's Avatar
RVAWagon RVAWagon is offline
Wire broke on Ignition Coil.... help please
So my 87 GW ran fine yesterday and when I went to crank it up today it was running VERY ROUGH and then would cut out.
If I gave it gas it would keep running but rough and then would die. It smells like it was running super rich. When I opened the hood I see this wire has broken. I'm assuming that this is the culprit, but how do I get it connected or find the name of the part to buy?
1987 Grand Wagoneer Stock
The original owner kept it in a garage and barely drove it, I bought it in Sept of '15 with 107K miles on the clock... so many of the parts that I pull off are still AMC originals.
Gone But Not Forgotten:
1993 Jeep XJ Cherokee
2000 Jeep TJ Wrangler
Old 08-17-2019, 09:18 AM
that is just a wire for the condenser which eliminates ignition noise, it wouldn't cause the issue you describe
Old 08-19-2019, 05:52 AM
RVAWagon's Avatar
You are correct sir and so wise Babywag!
So on Saturday I went out an found the part at NAPA and bought it, in line with "it's broke and should probably be fixed"
So for those of you curious the part number listed on the Condenser is "#3229510 648" and NAPA calls it an Alternator Capacitor and their part number is ECH M036
Well I had to get it ordered since they didn't have it in stock and I should have it tomorrow. I spent last night looking up the part and trying to learn more about what it does and from what I found it appears to control a lot of radio interference and no one seemed to to have the same problem that I did.
So I went back out to crank up the Jeep and see if I could better figure out what is wrong and the damn think fired up and ran fine! WTH!?!
So I let it idle for a while and then drove it around the neighborhood and then everything is wonderful again.
It ran great again this morning to work and I have no idea what the problem was Saturday morning.
coil resistor wire westcoastflea General FSJ Tech 11 02-08-2012 08:22 PM
no power to ignition no start westcoastflea General FSJ Tech 12 10-19-2006 08:30 PM
ok, this ones for J.Y.G. Lazarus General FSJ Tech 8 08-07-2006 10:29 PM
Ignition help and ID Heimeken General FSJ Tech 14 05-18-2003 07:20 AM
coil amp draw? / coil wire fire davez26 General FSJ Tech 0 05-05-2002 01:05 PM
