Old 08-09-2019, 01:31 PM
86GWABQ's Avatar
86GWABQ 86GWABQ is offline
Cruise vacuum question
Can anyone explain the purpose of the vacuum dump valve for the cruise operated by the brake? I understand the function of removing the vacuum from the servo. The reason I ask is because my valve has failed. I plugged the hose under the dash and the cruise still works the same and disengages electronically when the brakes are used. Is the valve a redundancy? Should I run it this way? Anyone have a part number for the valve itself?
Quick Cruise Vac Reservoir Question ThisGuyUKnow General FSJ Discussion 3 09-16-2014 08:48 AM
Vacuum question CoastGuardTruck General FSJ Tech 10 05-15-2014 01:50 AM
Tech Tip: Cruise doesn't work well and engine seems sluggish aatcman General FSJ Tech 3 05-31-2007 10:21 PM
Holley Truck Avenger Secondary Springs funwheeling General FSJ Tech 5 11-29-2006 09:44 AM
Front Axle Vacuum Question FrankenJeep General FSJ Tech 13 04-30-2002 02:49 PM
