I like it! Very handsome!
Your options for a trans swap are kind of limited with the 327. The Gen 1 AMC V8s have a unique bell pattern AFAIK, so look for a T-98 from a J-truck with that engine. You have good connections to that kind of stuff here.
Blocks on the rear, ok. Blocks on the front, scary.
The AMC 327 is a battleship of an engine. It will run and run and run if you change the oil. Steel crank, steel rods, lots of bearing surface, massive block. The starter can be a problem. I hear the position of the exhaust manifold cooks the starter - ask about the replacement gear-driven starter. OEM style starters are hard to find.
Excellent!
Excellent!
