10-06-2005, 04:06 PM
Delightfully Incompetent
I finally finished the rear disk brake conversion on my Jeep D60. After several months of working with a fabber back and forth, I finally received the final product. Those of you that have a J truck probably already know about the rear springs leaving very little choices when it comes to clocking the caliper brackets. Although, 10 o'clock would have been ideal, my best choice was to clock it at 4 o'clock. That leaves room for the calipers and caliper bolts.
The seller of the conversion kit includes everything including brackets, rotors, calipers, pads, flex line, bolts, nuts, washers, caliper bolts, spacers, and banjo bolts....all for $250. If you want a parking brake, add $150 for rear Eldorado calipers (which I got).
I'll be doing a write up soon. But, I still have to install that axle under my J10 yet and connect the brake lines.
[ October 08, 2005, 02:46 PM: Message edited by: J10Mike ]
www.j10mike.com
10-06-2005, 04:52 PM
looks like a great setup Mike. Price looks good too, if I didn't have my heart set on mogs I would look into it. Of course the way finances are I may anyway.
10-06-2005, 05:13 PM
SAWWEEET!! I want one! that is definitely on my "going to do" list!
man that is nice. and a nice price too. how do I get one now?! [img]smile.gif[/img]
A.K.A. Dion F. <br />92 XJ 4.6L HO Stroker <br />79 CJ7 Mopar 360 Magnum V8 MPI/NP435/D300 with 4to1 low <br />85 J20 Pickup AMC 360/auto/44 front/FF60 rear w/1000lbs of rust <br /><br />Insanity has replaced reason in the modification of these vehicles......
10-07-2005, 01:44 AM
don,
let me get the axle bolted up and get the braking tested. i'm sure it will work great. but, he (the seller) wants to make sure everything is a go before offering the kits for sale. as soon as i know something, i'll post his name and contact information.
www.j10mike.com
10-07-2005, 03:50 AM
Looking good, Mike.
steve
’86 J20
SOA, Dana 60's, F/R Lockers
Full High Steer, Ram Assist
Bunch of Other Stuff
10-07-2005, 04:28 AM
Please keep me posted Mike
P.J
Stupidity rules at all times! Famous last words "Hey, watch this" Its 5:00 Somewhere. 1983 J10 In process: 360 ci install
10-07-2005, 05:17 AM
very nice
would the caddy calipers be less if u had a core?
mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> [IMG]<br />[url=http://www.fsjworld.com/mygallery.ten?id=3481[/URL]<br />[/IMG]
10-07-2005, 06:12 AM
Originally posted by mark:
very nice
thanks guys.
mark, since i'm not dealing with a parts store, there is no core charge.
www.j10mike.com
10-07-2005, 06:28 AM
ive got insp comming up and this yr i really have to make it legal.im grandfathered in with my lift but ill borrow my sons 38 x 12.5s,im making big mudflaps as we speak,but i have ne ebrake.i was gonna make something on the back of the 205 but with my tank in the stock location there is no room.
10-07-2005, 06:38 PM
DONE...axle swap completed.
[ October 08, 2005, 01:13 AM: Message edited by: J10Mike ]
www.j10mike.com
10-08-2005, 08:41 AM
OK...added some more pics with brief descriptions.
Rear axle just bolted in.
Drivers side flexline connection to new and small hardline. This was less than desirable. However, due to where the splitter was located, there was no other choice.
Here is another view of the driver side flexline/hardline connection.
Here is a view of the more desirable passenger side flexline.
Here is a view of the new hardline strapped down with the oem clips.
Here is a view of the passenger side with tire on. The brackets/calipers tuck right in there nicely.
And lastly, just a pic of the driverside rear with tire on. I'm tired.
www.j10mike.com
10-08-2005, 08:45 AM
beautiful....I want one!!!!
'85 Grand Waggy 360/727/NP229 33X12.5R15 2inch susp lift with 2inch body lift.(wife's DD)
'86 Grand Waggy all stock with custom sagging springs
'85 Baby Cherokee 2.5L(my new DD)
'89 Chevy K2500 flatbed
'87 Ford Ranger
'84 Renault LeCar
'84 Honda Passport
'66 Yamaha MG-1T
http://www.jpricefamily.org/joy/Chris-Cars.htm
10-08-2005, 11:45 AM
Looks good,
I'll keep this conversion kit in mind when I get that far along.
76 J10 383 Vortec (CSFI) GMC 5 spd NV4500 NP241 No Lift and no 4wd yet. tc is on driver pumpkin on pass Build Thread
10-09-2005, 04:20 AM
neat setup!
are you worried about that short hardline fatiguing from constant vibration?
so the kit bolts to the original flange and there is no cutting / welding on the axle?
10-09-2005, 07:12 AM
not terribly worried right now. but, it's something i'll be watching.
yes...the kit bolts to the original D60 flange. no cutting or welding on the axle. if you wanted to go back to drum brakes, you could.
www.j10mike.com
10-11-2005, 08:46 AM
I've said it before, I'll say it again. I seriously want a setup like that!
10-11-2005, 09:02 AM
I haven't been able to drive it yet...Because, I have no brakes. Still waiting for the replacement extended brake line to come in. Maybe it will be on my door step when I get home later.
With that being said, I haven't been able to bleed the brake lines and test how well the conversion works. If everything is a go, I'll forward you his name and contact info if you are interested.
www.j10mike.com
10-11-2005, 10:15 AM
thats beautiful.
10-11-2005, 01:35 PM
360 AMC
Looks good Mike.
I can say that I hate bleeding the rear drum brakes on a D60. The spring pack is to close to the bleeder screw leading to a MESS!
Looks like you won't have a problem at all with that set-up.
J-trucks with Brows RULE!!!
10-11-2005, 02:22 PM
Originally posted by ColeTrickle:
Looks good Mike.
I hear that. But, no new brake line yet. I can't believe it takes 7 or more days to ship from Tacoma, WA. I could have been driving and testing Saturday morning. Maybe it will show up Wednesday.
www.j10mike.com
Thread Tools |
Display Modes |
