Go Back   International Full Size Jeep Association > Tech Archives > Drivetrain
Thread Tools Display Modes
Old 03-31-2002, 06:16 AM
jeepbob jeepbob is offline
Jeep Idiot
Post
Truce.
I am going wheelin, see ya all in the mud.
Matt have a happy Easter, same to every one else!BTW its run what ya brung and we all pull each other out! Try not to dig in too deep and have fun.
65 wag. with a bunch of stuff done and more happening.<br /><br />\"If the local junkyard calls you for Jeep parts, you might be a redneck\".... and yes they do!
Old 04-01-2002, 03:15 AM
Jerk
Posts: n/a
Post
<blockquote>quote:</font><hr>... on the exhaust side, the benefit I see to a tuned exhaust is cylinder scavenging. You create a negative pressure on the cylinder, thus it sucks out more exhaust and pulls more air/fuel in, thus bigger bang, thus more power.
Phil, this is true with TUNED headers that are run into each other through various means, some have "x" pipe between the two header collectors, some have "H" pipe in the same place, some ,like the '66-68 or 69 ford gt40s had a 360 degree system where the odd firing cylender on each side was run to the other bank and helped scavenge even more. This actually gave an exhaust sound more like a 6 cylendar since it was a smoother sounding. Also regular 4into 1 and sometimes tri-ys can be tuned to their respective bank(head) and you get the shock wave of one exhaust pulse arriving at the collector just when the next exhaust pulse enters the runner leading to the collector, thus "pulling" with it the next pulse, this is only effective within certain rpms and therefore, you must tune runner length as well as diameter to the rpm /power band that the engine will be running in. confused yet? [img]smile.gif[/img]
But isnt' the actual torque of the motor generated when the bang happens and the fuel/air mixture ignites? (This is only part of it, the middle part. This is the belief that too many people fall into, where they think "If I put a huge duration cam in my engine and leave everything else alone, I'll get radical power!" its a scale, all must be balanced- such is life)
Thus the motor is closed to the negative(or positive as the case maybe in smogged vehicles) (or ambient in Matt's ideal) pressure on the exhaust side, right? (sometimes this is true, it does depend on alot of variables. valve timing and the like as to when the exhaust valve closes...to be continued...)
Or is valve overlap such that at low RPM a high velocity exhaust will actually suck fuel/air out of the cylinder (or maybe reduce compression?) reducing torque?
This is an interesting question, as it can be true also, and false- if you have a long duration cam, you will, at low rpm (idle-2000 rpm lets say) have your intake valve opening and exhaust valve closing, causing not only the 2 gasses to intermingle fresh a/f mixture with spent exhaust gasses in the cylender, but also in the intake manifold and exhaust header, this is why most drag cars with lumpy cams sound really cool/sick when they idle, the plugs cannot ignite exhaust gas a second time so the engine sounds like its going to die. this problem alleviates itself as rpm climbs and the engine then makes a hellacious effort at turning rubber into toxic smoke! if you have a short duration cam, you will more likely not allow the exhaust system to "see" the intake system through the cylender. short duration cams also have a very smooth idle and run very well untill they hit high rpms, say 5000 rpm in a typical v8 where they really have no power, as opposed to the drag car that has rough idle and makes most of it's power at and above 5000rpm. Now, saying that, I'll say this, the exhaust pipe diameter, flow characteristics make almost no difference at idle or low rpm, idle to 2000 rpm. what it does do though, with headers, is allow for some extra scavenging throughout the entire rpm range of the engine, most noticeable at higher rpm, 2000 to 5000 rpm in the typical v8.
open pipes, larger diameter, just allow the pumping of the piston in the exhaust stroke to work that much less to free the cylender of spent gasses, the exhaust pulse from the burning(exploding more accurately) gasses doesn't exit itself into the cylender under its own force, but is pushed out by the piston which is of course tied to the crank making its work the result of a different piston's power stroke. now where the argument seems to be, apparently, (I don't really understand the thinking too well) is that larger pipe allows the exhaust gas to slow down and presumably it gets tired and finds a starbucks some where and waits to find a muffler to hang around in, while it drinks a mocha latte', then all the rest of his gas buddies do the same until you've got a traffic jam around the coffee bar and no one leaves. The idea that exhaust gasses moving fast like water down a waterfall is completely rediculous, it can be compressed (unlike fluid) and will back up or slow if restricted.) However, since even though the pipe is larger, and the gasses may not be moving as fast at a given rpm, there is still the same amount of them, just moving slower. this is good since it will allow more gas to be packed into a pipe (ristricted somewhat just by the nature of being a confined tube for containment or conveyance)without it being over packed and back pressuring the system as quickly, which would cause the piston's exhaust stroke to sap more power from the power available to spin the crank and make motion in the old drivetrain thus motivating the vehicle. In the smaller pipe, the gasses have to move faster and are more dense because they are RESTRICTED by pipe diameter and this will be more easily packed by the normal running of the engine, the longer the pipe the more it wil restrict also, although to a somewhat less extent.
Whereas more restrictive exhaust (read mid velocity) will scavenge the cylinder at lower RPMs without depleting the fuel/air mixture, right? (once again, depleting f/a mix is really only a concern with long duration cams)But a more restrictive exhaust will be just that (restrictive) at higher rpms causing exhaust gas to remain in the cylinders thus reducing power at higher RPMs? (this is acttually more likely, but like I said more likely if using a long duration cam, the exhaust valve is usually closed sooner not allowing this in most street driven v8s with a mild performance cam.
Thus why VVT (I don't mean to seem dumb now, but whats vvt? valve to valve timing?) flattens torque curves. You can have the right amount of scavenging for a larger RPM band right?
To answer this and hopefully wrap all this together, I'll say this: larger rpm band meaning broader power band (torque at low rpm and hp at high rpm instead of both at only high or only low rpm)yes, if you allow a larger exhaust pipe, you allow more flow, this translates into not only more axhaust gas, but the efficient handling(quicker exitting) of more gas, but it works on lower rpm as well as (designed for) higher rpm. Losing the exhaust gas and freeing the space it occupied for more exhaust gas is what big pipes are all about. this is only the exit side of the engines power circuit though, intake manifold, carb and intake port/valve in combustion chamber, is the beginning. spark, compression ratio/pistons, exhaust port/valves/combustion chamber, headers/pipes/ mufflers/cat, are the end. the cam is the brain behind the intake valve to the exhaust valve, everything else thats bolted on must be matched to it all and also to the vehicle and purpose.
help me out guys
Phil
Hope that helps phil. -Matt
[ March 31, 2002: Message edited by: Dive 30 ][/QB]<hr></blockquote>
[ April 01, 2002: Message edited by: Matt W ]</p>
Old 04-01-2002, 06:00 AM
Jeep Idiot
Post
VVT= variable valve timing and it works by changing the valve timing as the revs of the motor change to allow the torque curve to be changed.
Some headers for higher performance engines have a venturi in them to speed up the air flow and create an anti reversal area in the pipes to increase the scavange effect. This allows the the spent gasses to be drawn out of the chambers more effeiceintly. This style header works at higher revs and has little effect at low speeds.
180* headers combine cylinders from both banks to get the best possible scavange effect but again are only used on race motors.
This debate could rage on for months but until you actually get out and try different size pipes on the same rig will you actually find out what works best on it. On race cars to find the tune length you paint the exh pipe and go run the car. Where the paint burns off that is the tune length but you have to add 28 to 36 inches of pipe to it. The amount of pipe after the tune length will not make much difference as long as it is kept to the 28 to 36 inch point. A header gasket can take as much as 20 hp from a race motor.
Old 04-01-2002, 06:25 AM
Don S's Avatar
Don S Don S is offline
Geriatric Doctor of FSJs
Cool
NOW you got me thinking 'bout the simplicity of the single stroke engines.....At least the exhaust port is equil to the cylinder bore and with no valve stem to reduce the flow........Then, of course, there is the Ram-air intake box driven turbo...Putting 14.7 negetive lbs of pressure on the exhaust system. This does require a flame retarding system at the end of the tail pipe........I just love April Fools Day.....you know....I celebrate it every day........ ...ds..
Sold our 1976 Wagoneer 406, MC4300, TH400, QT, TruTrac, 2" lift, 31x10.50s, duel Optimas,
It’s took us over 161 Colorado Mountain Passes, 3 Jeep Jamboree USAs & 2 Ouray Invasions from 1985 to 2010
ACRONYMS & ABBREVIATIONS HERE
Old 04-02-2002, 07:41 AM
Jerk
Posts: n/a
Post
ah, thanks for the heads up on the vvt thing bob.
And I couldn't remember if it was 180 or 360 degrees, I figured if I got it wrong, someone would correct me, at least I got the function right..yes? as far as them only being used on race cars- sure, that's really the only place you would need the marginal advantage they would give. I know a couple of local dirt roundy-rounders out here and one of them used to drive Porches (not professionally, just drove 'em, and hard- he always did pretty good until some dingus put him in the wall or spun out in front of him and poor old Dave got caught in the middle of the dogpile everytime! I don't think the guy finished a season in 3 years simply because of getting his car munched. ) Any way, the other guy, Jodie, had some 180 degree headers and still couldn't compete w/ Dave, all else was pretty equal, both in a "mod" class, open wheels, tobular frame, 5 link rear suspension, using 400 chevy blocks and alcohol for fuel... and both were amatuer drivers, I asked Jodie if his tuned headers gave him any real advantage before he tried em, he said he hoped he could keep up with dave...after they ran a few races, he was pretty much of the mind that that wasn't gonna happen. heh- heh, he sold the car shortly after.
Now as to this header gasket thing using 20 hp...how does that work? curious. -Matt
Old 04-02-2002, 06:42 PM
Jeep Idiot
Post
On motors designed to run with no back pressure, and I am talking the high dollar Nascar and NHRA stuff not street motors, The cams, intakes combustion chambers, ports, and exhaust systems are designed to begin drawing air/fuel mixture thru the intake before the piston starts its down (intake) stroke. A leaking header gasket or broken header at the head allows outside air to be sucked into the system. This does 2 things, it decreases the amount of mixture drawn into the cylinder and also cools the exhaust which slows it down. That makes the whole system less efficeint and drops the hp.
On our street motors which are designed to have some back pressure, when the pressure is removed after a point the engine will go lean (non EFI) and you can not enriched it no matter what size jets you put in the carb. An EFI motor will go rich as the O2 sensor reads the lean mix and opens up the fuel flow to the point where the motor has to go rich. Primary header tube size has a rule of thumb also as you want to go just a little larger than the exhaust valve by about a 1/4". However you must also experiment here as if your motor never sees high rpm then a slightly smaller primary tube will be more efficient and create more low end power. I am by no means an exhaust system expert but have tried a few things here and there and found that what is good on a race car or even a light street car may not work on a 4wd or tow rig. Some times these lessons did not come cheap either as either broken parts or expendisure of cash to buy different ones because of disapointment were the result.
BTW the May 1999 issue of 4x4 Power magazine has a real good article on how exhaust systems work and they actually used 4 or 5 different vendors in the writing of it with no endorsements. There is even a chart on what size pipes to use with the power and size of the motor, although it looks like the recomendations were made for cars and not trucks which tend to run about 1/4" smaller for more low end power.
[ April 03, 2002: Message edited by: jeepbob ]</p>
Old 04-03-2002, 03:11 AM
Jerk
Posts: n/a
Post
hm, interesting. I agree btw about going with slightly larger runner tubes than the exhaust port, it helps stop reversion greatly, its just hart to find them for less than $300! for a jtruck anyway. and with our goofy dogleg ports, its a pain to bend tubing to fit the pattern w/out screwing it up, I imagine. I'm not so sure about the leaning out deal but hey, I've never heard the opposite either, it just seems slightly...um shall I say: "far-fetched", again I claim to be no expert here either, just read alot of what people have done and found proveable, repeatable advantageous gains with. - Matt
Thread Tools
