Old 05-14-2019, 04:56 AM
gilbedw gilbedw is offline
Flexplate question
I have looked at every post about flexplates that I could find but could not find an answer to my question.
I have an 81 Cherokee 360 & 727. It has a bad engine. I have 73 GW 360 & T400 which has a good engine. I want to swap the 73 engine into the 81 Cherokee and keep the 727 transmission.
Will the 73 360 mate to the 727? If I need to swap the flexplate will that affect the balance? Is the pilot bushing the same for both transmissions?
Old 05-14-2019, 07:05 AM
babywag babywag is online now
Yes, it will bolt up. You must swap on the newer 727 flexplate.
The 727 Jeeps did not use a crank bushing.
A 73 would have had an adapter/spacer setup w/o a bushing like later th400 equipped Jeeps.
1994 Caprice wagon
Old 05-14-2019, 12:05 PM
Thanks for the information.
Old 05-19-2019, 02:18 AM
BootsC91 BootsC91 is offline
Also the 360s are balanced externally, idk if thats throughtout thebyears but double check if yours will need to be balanced with new plate
'83 j10 86k miles orig. 360 AMC, tq727 and np219 sitting on either 35 or 31s. Custom bed, custom bumpers,(rear is a air reserve) with more in the works
Old 05-19-2019, 02:12 PM
you get a flexplate that is for a 360 and run it,. you don't tear the motor down and have it balanced whenever a flexplate is replaced.
Old 05-19-2019, 04:59 PM
redwoody redwoody is offline
does ur 727 convertor come with ring gear or an actual flywheel? My jeep convertor came w/ no ring gear no weights and 10 in bolt pattern
88 GW hei E-fuel pump 360
Flexplate question??? With big pic.... Wagoncrzy General FSJ Tech 11 12-21-2007 04:59 PM
401 Flexplate from NAPA wrong? flyusmc General FSJ Tech 2 11-19-2007 10:19 PM
401 Swap Flexplate? Mark Wilde General FSJ Tech 9 11-17-2007 10:45 PM
New Flexplate Problems Ranger General FSJ Tech 7 01-01-2003 06:12 AM
OT- flexplate to torque converter PAJEEPER General FSJ Tech 4 06-10-2001 05:38 PM
