Old 05-13-2019, 01:10 PM
360 AMC
What do you folks lube your window tracks with?
Just installed new window felts and scrapers on my tailgate and now the motor sounds like it is having a hard time. I read somewhere you can put some sort of lube on the fuzzies to help the windows slide easier. True? If so, what do you use?
Old 05-13-2019, 01:53 PM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
I remember new car dealers using spray silicone
but i am sure it makes a mess.
Old 05-13-2019, 02:02 PM
+1
Spray silicone works fine. Not messy at all but it's not a cure for an out of alignment binding piece of window glass. Just a bit of yearly preventative maint.
Old 05-13-2019, 06:24 PM
Tripwire's Avatar
Tripwire Tripwire is offline
+2 sillicone, also as an experiment try raising the glass with the gate ajar to see if its faster it could be rubbing too hard against the weatherstripping on the upper body as it goes up ... the fuzzy tracks are adjustable and a slight tweak can make all the difference
steve
Abort? Retry? Ignore? >
Old 05-13-2019, 06:57 PM
360 AMC
Good info! I will get some spray silly cone.
I noticed the adjustment when I installed them but am not ready to adjust yet (waiting on another part). I'll probably do both (lube and adjust). What is the best way to align it? Is that in the service manual?
Old 05-13-2019, 07:51 PM
Tripwire's Avatar
i dont think so, but its pretty obvious , use a popsicle stick or something to measure the gap inside and out at 1/3 way up and fully closed, the should be reasonably even, with a slight preference to being tighter on the inside, you are not really keeping out water, just wind noise/ whistle it took me several attempts to find the sweet spot, and dont assume both sides of the glass should be the same as the tailgate often does not "sit" square in the opening - that can be adjusted some what, but its a pita
steve
Old 05-14-2019, 07:46 AM
Best way for all glass is with regulator disconnected.
When adjusted glass should slide up/down very easily.
New seals will add slight drag, and new wipes/scrapers will add more.
With adjustment bolts/screws snug but loose enough to move they'll self adjust then tighten them down.
Some aftermarket wipes/scrapers are very stiff/poorly made and adds a lot of drag. These should be installed after glass channels are adjusted.
1994 Caprice wagon
Old 05-14-2019, 07:40 PM
Syl-glyde
It’s like a silicone grease in a tube.
Old 05-17-2019, 06:49 PM
SkylinePCG's Avatar
SkylinePCG SkylinePCG is offline
My take on lubing: petroleum-based stuff (WD40) works best IF you can replace it at regular intervals. I say that because the oil in it latches onto dirt, and eventually defeats the original purpose.
If access is difficult-like a key hole or Window tracks, then a spray silicone is a better option for the application.
1980 Cherokee WT
360, 727, 219, 35s
Holley 4bbl, Edelbrock performer intake/cam, TFI, Hedman LT headers, HB brakes, aaaand GW seats!
Still on the shelf... Hamilton EFI, Transgo TF-2...
Need Help with new window seals '89 GW Texafornian General FSJ Tech 13 04-18-2019 11:05 AM
1991 window regulator lube Johnkielle General FSJ Tech 5 04-03-2019 07:24 PM
Rear Window Install -- what did you use to seal the window to the lower bracket rmorit01 General FSJ Tech 8 03-30-2007 05:37 PM
1982 Window Assembly. Keebler General FSJ Tech 4 05-23-2005 03:55 PM
Window Gremlin - -Intermittant SamoyedSled General FSJ Tech 2 03-18-2002 11:42 AM
