Old 05-09-2019, 11:40 AM
Distordera Distordera is offline
Need help with door latch on J20
I really need some help with trouble shooting my door latch on my -81 J20.
When I open the door from inside the car the door latch "falls down" and when I try to close the door the latch has the wrong angle and I can't close the door.
The solution is to get out of the car, press the open button on the outside handle of the door and manually correct the angle of the latch.
Then I can close the door normally.
Are there any solutions for this?
Old 05-09-2019, 06:35 PM
backroadin''s Avatar
I think there is a small spring that keeps the latch from doing that when you operate the handle? Just thinking out loud........
It's kindof a pain to take off the inside panels, but if you took off two, you could compare.
Old 05-17-2019, 10:09 AM
Yes! Thank you for the tip.
I have a pic with the defect spring.
Does anyone know where I can buy a new latch assembly and what article number? Preferably one of the large resellers (Jegs, Summit) because it's easier to import to Sweden.
Jeep J20 apache j20apacheh General FSJ Discussion 23 10-12-2016 09:06 PM
Towing a J20 on a Uhaul trailer jpcoutts General FSJ Discussion 9 08-08-2013 07:07 PM
J10 vs J20 Frame ? jeephabit3 General FSJ Tech 5 03-30-2012 06:27 PM
J20 axles in a J10 - Driveshaft ? HOOT General FSJ Tech 5 06-19-2008 08:36 PM
Factory J20 5/4 ton??? Elliott General FSJ Tech 17 09-20-2004 01:55 PM
