Old 05-08-2019, 08:34 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
FIREWALL INSULATION1976 J-10
the shop who is taking the 76 j10 apart
just called to say I need firewall insulation.
in all other restoration,....
I have used dynamats "dynaliner" foam on floor
after applying the heavy foil/tar NOICO stuff on metal floor first
for vibration dampening.
will this be fine,
or do I need something else for further up firewall ?
( I think what I have used is far better than OEM firewall material, of shredded material and black cardboard )
any advise ?
dave in NC
Old 05-08-2019, 08:41 AM
SJTD SJTD is offline
Kaiserjeeps is making firewall pads. Search his build thread.
I covered mine with foam and MLV. Gotta put up the pics of the vinyl.
Sic friatur crustulum
Old 05-18-2019, 05:31 AM
fsj454 fsj454 is offline
Long time member
Both
I used FatMat and factory insulation . Hard to tell if it working with big block and large tube headers .
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 05-19-2019, 08:17 PM
Kaiserjeeps's Avatar
I don't now if my pre 1971 Kaiser era parts will work on something as new as 76. I don't really have any way to tell short of having the old part, or a picture of it. I know we talked about this Dave. But I thought I would respond anyway. Is there any way to lay the old one out on the floor and snap a photo? When Todd the welder posted a picture of his 80's pad, I saw it was a completely different piece than what I make. It would be nice to know what years the earlier Kaiser pads will fit. I just don't know. ....yet.
Am I done yet?
1969 1414X Wag,
1970 and 71 project J trucks
1970 Wagoneer Not Sadie
1953 Willy's wagon
1983 FJ60 wagon
Old 05-19-2019, 09:01 PM
asphaltrockdweller's Avatar
LOL I had originally bought this for my 76 Waggy, but since my Waggy is not ready for it I used it on my XJ.
The silver side is what gets glued down to the metal.
This stuff was kinda pricey over at Sumitt, but not as bad as the liner materials.
I reworked the interior of my XJ, and the upholstery supplier I was going to sold this product only quite a bit thicker, and less expensive.
Super happy with this kinda stuff. I used it on the firewall, and floors, then use fatmat on the roof, sides, and cargo area.
Old 05-20-2019, 07:55 AM
SOLSAKS's Avatar
thanx kaiser and asphalt
don't have original
wil prob go the aftermarket insulation route.
thanx again
dave in nc
Old 05-21-2019, 06:58 PM
Long time member
j truck
I have one that I removed from 79 truck. It is in sections now but so was mine when I installed I will dig thru piles to see if I have all sections. Can be restored
Old 05-23-2019, 01:22 PM
SOLSAKS's Avatar
cool
sounds good
thanx fsj454 AKA "Caveman"
Old 05-25-2019, 05:19 PM
Long time member
1 piece
Checked firewall pad it is in 1 piece and in good condition .Can be restored
Old 05-31-2019, 05:03 PM
360 AMC
Originally Posted by asphaltrockdweller
WAIT!! What happened to your XJ?!? (background)
Attention everyone who bought one of my firewall pads Kaiserjeeps General FSJ Tech 4 02-28-2019 07:36 PM
Factory firewall to engine clearance on '88 wag? Mavawreck General FSJ Tech 6 05-22-2011 06:44 AM
Help needed on '67-'73 firewall measurements Elliott General FSJ Tech 23 03-03-2010 07:24 AM
chevy/jeep wiring harness firewall connector uglyjeep General FSJ Tech 3 09-20-2009 08:12 PM
Vacuum lines coming out of the firewall? silvercert General FSJ Tech 1 02-12-2009 09:09 PM
