Old 08-30-2018, 05:21 PM
360 AMC
Should there be an O-ring or crush washer on the oil pressure sender elbow?
I'm about to put the oil pressure sensor and elbow back on my 401. The elbow is all clean and painted. Just about to install when I realized I am not sure how to seal it... Does it just get a little RTV on the threads going into the block? Should there be an O-ring on there? A crush washer? For clarity, I am only speaking on the elbow that threads into the block, not the actual sender.... actually, Same question for the sender...
Old 08-30-2018, 05:26 PM
I’ve never used anything on them just snugged them down.
They’re NPT so unless threads damaged should seal.
If you’re worried about leak(s) use some teflon paste/tape.
1994 Caprice wagon
Old 08-31-2018, 10:30 AM
As Tony said, it's pipe thread so it's the threads that do the sealing.
Old 08-31-2018, 10:34 AM
If you do use tape, don't put it on too thick as the sender grounds to the block & you'll need a thread or two to break through the tape.
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 08-31-2018, 04:15 PM
360 AMC
copy all, Thank you Gentlemen. I put it in, dry. Hopefully (probably) it seals.
Old 09-05-2018, 01:02 PM
WHY DID NOBODY TELL HIM IT TAKES A LEFT HANDED METRIC ORING???
Old 09-05-2018, 01:21 PM
360 AMC
BWWAHAHAHAHA!!!!!
I used a little prop wash to clean it, lubed it up with some relative bearing grease, and gently torqued it in with a left handed crescent wrench. I am hoping those will help prevent it from leaking...
Old 09-05-2018, 03:06 PM
I put it in dry.
Am I the only one who giggled at this or has the military corrupted my mind?
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1984 J10 - Parts
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Oil Pressure Sender Fittings? Walt General FSJ Tech 3 07-10-2005 04:29 PM
oil pressure sender yoslvr442 General FSJ Tech 3 07-05-2005 07:28 AM
Oil pressure sending unit PhilSine General FSJ Tech 5 06-15-2003 07:30 PM
So where can I get a new oil pressure sender? BIGYELLOW78J10 General FSJ Tech 8 09-27-2001 03:23 AM
woh...woh...WOH...got no pressure spring? got no spring cup? SlickKipper General FSJ Tech 14 06-05-2001 11:30 AM
