Old 06-26-2018, 09:37 AM
medinajim2000's Avatar
medinajim2000 medinajim2000 is offline
85 GW Champagne Metallic
This one should be here either this week or next. Haven't had a gold one in a while. Can't wait.
https://www.facebook.com/ClassicGrandWagoneers/
87 GW (White) - Incoming
89 GW (Black Cherry) - In Resto
85 GW (Gold) - In Resto
86 GW (Garnet) - In Resto
84 GW (Bronze) - In Resto
89 GW (Gray) - (Gone)
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
75 Cherokee S (Blue)(Gone)
Old 06-26-2018, 12:51 PM
ProTouring442's Avatar
Nice color.
Old 06-26-2018, 09:33 PM
Ooo I love the pre-'86 Grand Wags
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1984 J10 - Parts
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 09-24-2018, 12:34 PM
Got the woodgrain and trim removed. Next is dent removal.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 09-24-2018, 12:46 PM
I ordered some corduroy samples, trying to get as close as I can to the original. Still not happy with any of these, but running short on options.
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 12-04-2018, 08:02 AM
This one has been on hold for a little while. Last night tho, I did get around to finally matching the interior colors so I can refinish the worn trim, armrests and make one of my consoles to match. After trying a lot of different cans, I finally found an almost perfect match or Leather, Vinyl and Plastic refinisher. What do you think?
(the plastic piece is the original and the armrest part is the refinished piece).
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 12-04-2018, 08:48 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
looks good jim,...
that will be a nice wagoneer, ...gold is cool.
i have seen that ribbed fabric before
when i was looking for alternatives,....
you know, the caravans and voyager vans of the 80s/90s
used very similar, if not the same, cloth inserts as wagoneers
i wonder if any of the new old stock suppliers has some for vans,....
.......worth a try.
dave in NC
Old 12-04-2018, 09:21 AM
.......worth a try.
dave in NC
I didn't know that, but it makes sense. Thanks for that info. The search continues. lol
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Old 01-02-2019, 04:42 PM
letank's Avatar
letank letank is offline
Nice work, which technique, the rubber wheel or the heat gun?
And for the armrest which paint reference number did you use?
Thank you
Michel
Old 01-03-2019, 12:57 PM
Subscribed!
Old 03-26-2019, 02:21 PM
dtatum dtatum is offline
Jim, do you remember which paint color you used for the arm rest? I desperately need to do that with my faded Honey arm rests.
Thanks!
my 1984 Grand Wagoneer in Ice Blue Metallic x98boardwell General FSJ Discussion 2 08-29-2014 03:41 PM
Metallic clang when going over bumps. Jeepguy77 General FSJ Tech 25 07-25-2012 07:08 PM
Magnaflow/Carsound High Flow Metallic Converter ChileWaggy General FSJ Tech 2 10-21-2008 10:31 PM
autumn honey & champagne metallic 18cherokee General FSJ Tech 2 12-15-2004 11:24 AM
