Old 05-05-2018, 11:12 PM
His-N-Hers Woodies His-N-Hers Woodies is offline
His and Hers LS Swap Double Build
Long story short...I was building the wife an '89 GW (Woody #1) when a much better candidate (Woody#2) landed in my lap. The plan is to get #1 (his) driveable while #2 (hers) get's an LS swap, paint and all the goodies. Both are blue 89's.
EDIT:
Parts list: https://drive.google.com/open?id=0B8...LUVVR VJWNEhJ
Some things I will do differently on the second build (His) :
-Go with 3.73 gears instead of 3.54
-Rear mount gas tank instead of spending so much time making the stock tank work with a universal sender and intank pump
-Buy a motor/trans combo from a guy about 2hrs away who sells them turnkey instead of dealing with a donor truck. I couldn't use near as many parts as I thought I'd be able to and pricewise it was probably a wash.
-Go with a smaller fuel pump than the one linked. I had to wire an extra relay to handle the current.
Start:
Finish:
Old 05-05-2018, 11:13 PM
Old 05-05-2018, 11:21 PM
Bad Rust on #1 rockers
New rockers from team grand wagoneer going in OK for my first time doing this. Made new inner panels from some steel shelving I had leftover from a project.
Old 05-05-2018, 11:24 PM
Also got new springs/tires installed. The Spring u-bolts all had to be cut. The install took several days, way longer than it shoudl have.
Old 05-05-2018, 11:28 PM
MEANWHILE....
I bought a donor truck for the wife's jeep LS swap
Old 05-05-2018, 11:29 PM
Old 05-06-2018, 01:59 PM
Achilles's Avatar
Achilles Achilles is offline
Looking forward to seeing this unfold!
YouTube: http://www.youtube.com/channel/UCmcfvYSDdeFJ-NHY1MA_9Iw
Old 05-06-2018, 07:30 PM
JPSwapMohn's Avatar
JPSwapMohn JPSwapMohn is offline
Looking forward as well. The dang pictures just show up as little empty boxes on my ipad.
One day I will wake up and realize that my jeep is complete...one day, I just know it.
88Wag, LT1/4L60E/NP242, F150 fuel cell, discs, Aussie rear, LDS front, 4.10s
http://imgbox.com/g/rNuIasKYrS
95YJ, STaK 300, D44's, SOA, ARB's, 4.56s, Bilsteins, 35" KM2's
50 CJ3A
77 J-10, 360/T-18/D20, SOLD
Old 05-06-2018, 07:58 PM
Achilles's Avatar
They show up just fine for me.
Old 05-07-2018, 10:57 AM
Yeah, I see them, too.
Old 05-07-2018, 05:35 PM
JPSwapMohn's Avatar
They are there tonight. No idea, maybe i had a crappy connection last night.
50 CJ3A
Old 05-10-2018, 08:12 PM
Trans is getting gone through by a buddy and not looking too bad
This guy can't be trusted in the house, so I have a new shop helper. Pulling the harness to have it converted.
Old 06-25-2018, 07:56 PM
OK Finally making some progress
Ready to pull the engine on Her's
I decided not to pull the front clip/rad support and realized I should have. So I improvised and cut the radiator support out. I'll weld it back in later. Dog agrees.
94 Degrees here in TN and I'm thankful for a/c in the shop!
Old 06-27-2018, 11:12 AM
ProTouring442's Avatar
Cool deal!
Where in Tennessee are you?
Old 06-28-2018, 07:32 PM
Originally Posted by ProTouring442
Cool deal!
Jackson
Old 07-01-2018, 06:17 PM
Wife helping clean the carpet while I fix the lawn mower
Novak conversion mounts test fitted
Getting ready to mate trans to motor.
Old 07-13-2018, 10:42 PM
Engine bay close to ready
Old 07-13-2018, 10:43 PM
Interior shot while seats are getting reupholstered.
Old 07-13-2018, 10:45 PM
Tranny built and ready to go with motor
welded a half coupling into the pan for a temp gauge
Old 07-13-2018, 10:47 PM
Work continues on fuel lines. Steel lines with braided hose/AN fittings. Not a fan of compression fittings.
